Volks AutosAH Fabrications
Results 1 to 8 of 8
    Jun 2012
    285
    19" 8j wheels all round - what size spacers?
    As above, what size spacers can i get away with front and rear?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    10mm front 15-20mm rear, based on using 235/35R19s
    You've got to have a laugh!
    olethalb's Avatar
    Aug 2012
    312
    completely depends on what offset the wheel is
    (if there is a pic i apologise i don't get access to pics at work)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by olethalb View Post
    Of course this information is correct, my reply was based on wheels with ET35 offset, basically, the range is ET25-35 on the fronts and ET 20-35 rear, you could probably run 20mm's on the rears, I'm pretty sure that will clear.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    I run ET5 rear on 8.5s, if it wasn't for that stupid little plastic "block" on the outside arch liner, it'd be fine. Rubs ever so slightly now and then...
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    May 2011
    184
    ET53 Alloys, 19x9's, 35mm spacers front, 45mm spacers rear and fits fine. What wheels are you looking to put on?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by ci-ryder View Post
    Making them ET8, must be some rather long bolts you are using though...
    May 2011
    184
    Yep they are, sadly I need to find one longer one as I damaged part of the thread on one of the adapters
  1. Brakes all round ! what would you recommend?
    By bing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2012, 23:31
  2. does anyone know what make these wheels are and what size ?
    By S3 JOHN in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2012, 10:41
  3. What size spacers are best for S3 standard 17"wheels ?
    Last Post: 23rd December 2011, 16:51
  4. Hello! its my first post - What size spacer's should I get?
    By Dan76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2009, 15:39
  5. What size spacers for 19" rims??
    By amoani in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 14:41
