Monster MotorsportChris Nott
Results 1 to 15 of 15
    Jul 2012
    24
    Help Car cut out while driving
    Need some help, was out in the car about an hour ago and car died whilst driving down road so started her straight back up then did same after about 500yards. Pulled up tried to start engine and all it did was try and start and not fire up. As I waited for me dad in the ranger to tow me back it started up again, but after a minute cut out and keeps doing this. Just before it cuts out every time the triangle warning light with the arrow going around the outside of it comes on.
    Before it started back up I checked the belts and they was both on. Next thought it could be fuel related such as diesel pump or injectors.
    Can anyone else think what it could be or had similar problems. The car is a 1.9tdi.
    Help!!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Not to up on soot chuckers but it sounds like a crank sensor,
    Nov 2012
    34
    Yup, second that.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    Mine's been doing this. Dodgy idle and sometimes just cuts out but starts straight back up again. Mine's a complete loss of power like the key has been removed or turned off though. Would it be the same thing?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Jul 2012
    24
    Right will have to get busy this weekend and sort it. Cheers guys.
    I didn't notice irrational idling but it was just like the key turned off.
    Nov 2012
    34
    Quote Originally Posted by Mark24a3 View Post
    A bit of a long shot I know, but if you can your hands on an oscilloscope you could check the output of the crank sensor. You should get nice square wave, if it's shot just a line.
    When crank sensors f**k up it's normally when they are warm, I assume it doesn't do it from cold?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    Sounds familiar. Might have to try changing mine...
    Nov 2011
    Finland
    131
    Quote Originally Posted by Sam_ View Post
    Mine did exactly the same last summer and the fault was the crank sensor.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    Looks like you have to remove the oil filter to get to it, is that right? I just done a service :'(
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    No Sam you dont need to remove the oil filter but it is a ***** to get to...
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    from memory it is a 6mm alen type bit you need
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    Are we talking themostat levels of annoyance?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    ERM i would say slightly more,,, you can feel but you cannot see, once you get your bearings it is pretty easy...
    May 2012
    Staffordshire
    50
    A bit more fiddly, I had the same problem last year on my Corrado 1.8T.
    GSF replacement was about £20 and served me fine.
    2002 3.2 24V S32
    Feb 2012
    Pie eating land
    871
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    Help!!!
    Does your glow plug light flash? Usual sign for cranksensor on oil burners
    B6 1.9tdi Quattro Avant Sport,
    Full zenon bulb kit, Plug and Play chip @165bhp, EGR Delete pipe, Chrome Mirrors, Chrome side repeaters, wind deflectors, Front center arm rest, LED number plate bulbs (when they work), Rear tints, De-Badge Rear, 19" BBS LM's,De-Wiper
    Coming soon -35mm Springs, De-cat pipe.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch, Stereo upgrade, Full Stainless with twin exit !
    Chuck it in & pin it out, nothing better than doing it in the dirt !!
  1. Replies: 15
    Last Post: 7th May 2012, 00:51
  2. HELP!!!!! CAR CUTTING OUT HELP!!!!!!!!!!
    By dannyvalley in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2012, 20:20
  3. Car cut out, won't turn over. Help!
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2011, 18:51
  4. HELP! Accelerator cutting out while driving. A4 B6 S-Line
    By zvi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2009, 23:17
  5. Car cuts out at low revs, while heavy steering input is made
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2008, 12:13
