    S3 Paul's Avatar
    Oct 2006
    2,759
    A few issues, What do these point to??
    As part of my winter check over / service of the car ive decided to try and resolve a few long standing issues.
    To clear up what the car is and has...
    2001 S3 AMK
    rebuilt / forged engine about 2 years back,
    FMIC, forge boost hoses and DV with uprated spring
    Jetex filter
    JBS05 spec TD hybrid , 3 inch downpipe and miltek system.
    Haldex blue controler... blah blah blah
    First worry/ issue is a noise that sounds like ( granted a quiet one but) an external waste gate if i lift off from part throttle , doesnt happen if driving quickly or changing gear just if i lift off .
    DV problem? or turbo issue?
    The car...although drives very well and feels realy strong gives poor MAF readings on VAGCOM logs.
    Against cars that are of same kind of power i hold my own but the logs show numbers that only relate to 250ish bhp? Dodgy MAF or something else. No fault codes are shown.
    The car can feel like it is realy eager to go. if that makes sence?
    Like the smallest throttle input realy makes the car want to fly off,
    Any help? ideas?
    My plans are to drop the oil and filter check for boost leaks and i have a spare MAF sensor i can try?
    Noggy Blue 2001 S3
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Paul what TIP do you run? I previously run a Forge tip and green panel filter. I used to think I had a maf problem as my car was giving g/s readings of below or just about 200g/s, once I fitted a b5 tip and jetex I instantly see gains of over 20g/s everytime I give it some stick. Also it felt so much better like it was able to stretch its legs for once.
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I would give the throttle body a good clean out, give it a good service inc DV and go from there...
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well today i managed a few of the jobs on the list...
    I removed the throttle body and gave it a clean and reset it ,
    I then took the DV off and stripped it down...
    I was unsure what spring was in there. Its a yellow one, is that right for my set up?
    I cleaned everything down and checked for wear... the piston had a mark on it... just a mark, no ridge so thats ok? the bottomof the spring looks a little bashed to be honest . like its well used, But the inside of the piston is fine... strange
    On the breaf test drive home... car feels like its old self again. happy days so far!
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Did you regrease the DV piston Paul? if not it will be short lived...
    S3 Paul's Avatar
    Oct 2006
    2,759
    I did yes. The sides or the bottom/ sealing end? I smeared the sides/ sliding part of the piston with multipurpose grease.
    That ok?
    Noggy Blue 2001 S3
  1. What are these calipers from ???
    By noslojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2005, 22:02
  2. Help needed!!!!!!!!! Any idea what country these cars are from?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2005, 23:06
  3. what are these wheels from?
    By SQ_lover in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th April 2005, 20:59
  4. Passenger seat - what are these metal things...?
    By skempster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2005, 17:27
  5. Just had 1.8T Sport chipped... few issues?
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2004, 10:42
