AH FabricationsChris Nott
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    02 S3 Scan Fault code thoughts !
    Just did a scan on the S3 as i'm aware something is up the EML & some hesitation uner boost, got the following.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 01 0001
    Coding: 10710
    Shop #: WSC 00000
    VCID: 78836BE34BCB
    2 Faults Found:
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 35-00 - -
    16502 - Shareware Version. To Decode all DTCs
    P0118 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Can a lamda sensor influence fueling enough to cause hesitation ? or could this be an issue with the MAF ?
    Any help would be great
    Regards
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    check your o2 sensors mate.. might be wiring or you might need to replace them ... no other fix comes to mind .. or try to clean then maybe ?
    Nov 2005
    UK
    1,689
    yeah i need to get under there & take a look, if anyone has the part number that would be helpful
    wanted for 8L S3:
    Milltek system
    Jan 2011
    Australia
    1,316
    best bet is to call awesomegti think u can get both for 180 pounds iirc and genuine. qoute Mike there you VIN and ur gd
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
