Volks AutosChris Nott
Results 1 to 13 of 13
    Gizmo20VT's Avatar
    Jun 2012
    289
    38mm Tial WG overboosting
    Hey peeps
    I have seen some WG threads but dont want to thread jack them so started my own.
    I am using the bottom port setup with N75, and Im experiancing overboost thou. Would a stronger spring be needed for increase cracking pressure? Im on a 9 psi spring, my boost request is 2200mbar and my actual boost is 2400mbar.
    My N75 pressure source is from the 6mm nipple under the intake manifold, would this effect my setup at all as its still giving positive pressure under boost?
    Note: I have corrected by boost request line in my software, same effect.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    as per your posts on nef
    N75 PID/duty cycles will need adjusting in your map
    what actual pressure does it run with n75 electrically off?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    .6 bar (9 psi) unplugged
    The other night it boosted .9 and wouldn't budge further. Have done a boost leak test and no leaks confirmed.
    Also the PID is still adjusted to my stock my, so LDRXN should still limit the actual boost to meet requested?
    I have tested another N75 same result, .9 bar and then 1.4bar +, when I use the setup in the link below I also get .9 bar and the WG is open, can hear screamer pipe clearly.
    http://www.tialmedia.com/documents/w..._wginstall.pdf
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    LDRXN caps load, but is not the PID for the n75 - different thing
    big question being why is it so slow to spool? 5krpm sux
    my hybrid GT35's spooling then...
    for N75 control, you would use the bottom port not both top and bottom.
    leave top ports open.
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    Yar I know, I never expected so much lag with this setup, even with a .82 housing on a T25 frame.... Im really not sure what else to do about it. I know I can change over to a .64 i think or .63 but AFAIK it wont increase by more than 400-500rpm.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    what size/length runners on the manifold?
    bill@badger5.co.uk
    BENJAMIN's Avatar
    Mar 2011
    459
    This is my old s3 on a t25 .82 3071r. ATP log mani. Similar spool to yours, .82 was a too large for the displacement me thinks.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    0.6x for stock displacement motors imho...
    0.6x is'nt going to bring spool back to 3krpm, so something else is going on.
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    Im sorry I cant really provide the correct info on this, can supply you with a picture thou.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    what diameter runners?
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    what turbo?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    what turbo?
    lol, not noticed he's not said in this thread... saw it elsewhere..
    GT2871/0.86 hotside T25 I believe
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    Yip GT2871R .8x hotside. Stock AMK 1.8T motor.
  1. overboost
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2007, 22:22
  2. Turbo Overboost
    By welshdragon in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 07:57
  3. Overboost in VAG.COM
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th October 2004, 16:53
  4. overboosting?
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2004, 13:19
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
