Volks AutosAH Fabrications
Thread: block 125
    Sep 2011
    Scotland Dumbarton
    246
    block 125
    Ive been having issues with my abs.... i.e abs light traction control light and the fault code 01316, implying a communications fault. Ross tech tells you to chech blocks 125 and onwards. It doesnt however tell you what values you should be getting im getting a value of 1 under the abs field but have no idea what this actually indicates????
    Noggy blue Bam engined S3. Complete with cr turbos stg4 turbo, xspower mani, dp and sports cat, rifle drilled IE rods, 550 injectors, forge 007, badger5 v2 tip, jetex with heatshield, wellycooler, catch can, weitec lowered shocks +springs, 15mm front 20mm back spacers, rtech custom map
    304bhp 290lbsft wmi soon to be fitted along with 986 brembo fronts!
    Sep 2011
    Scotland Dumbarton
    246
    Anybody got any clues?
    Sep 2011
    Scotland Dumbarton
    246
    Bump...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    http://www.ross-tech.com/vag-com/m_blocks/120-129.html
    01316 - Ross-Tech Wiki
    01316 - ABS Control Module: No Signal/Communication
    Possible Causes
    Wiring/Connector(s) from/to ABS Control Module faulty
    Fault(s) stored in ABS Control Module
    Possible Solutions
    Check Wiring/Connector(s) from/to ABS Control Module
    Check Measuring Value Blocks (MVB)
    Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Can you connect to the ABS control module in VCDS (03 - ABS Brakes)?
    <tuffty/>
    Sep 2011
    Scotland Dumbarton
    246
    it was mapped at r-tech. i've been to block 125 and the boxes say gearbox abs and intsrument cluster. i have no value under the gearbox coloum and 1's in both the abs and instrument cluster, but am unsure if this is a good thing. I cant access the abs using my ebay cable, so im waiting on a ross tech one coming. Im only getting this code on the AWD module.
    Any ideas...
  1. New Kid on the Block w/o the boy band overtones
    By moralkombat in forum The Welcome Section
    Last Post: 25th October 2004, 10:10
  2. new guy on the block
    By imported_nmb in forum The Welcome Section
    Last Post: 20th August 2004, 20:16
  3. New boy on the block
    By imported_scotthamilton in forum The Welcome Section
    Last Post: 16th August 2004, 10:50
  4. Cat Block
    By MisterD in forum General Technical / How To
    Last Post: 20th October 2003, 11:12
  5. New kid on the block
    By stobbie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2003, 22:09
