Volks AutosEM Tuning
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Fans coming on - Friend's 1.6 A3 BLQ - fan switch or...?
    Hi guys,
    Been a while, so hope you lot are well!
    Got an email from a mate of mine the other day, asking about advice on his 1.6 A3 - this was his email, can anyone shine any light on it? I have suggested it might be the temp sensor/sender as my S3 had a similar issue with the temp not being at 90'C and that fixed it... the other point might be the fan control switch, from a quick search on here?
    "This is a bit random, but I'm having a problem with my 2003 8l A3. It's got the 1.6 BLQ engine.
    We I start the car from cold or hot both fans come on. If I turn the climate control off no fans come on.
    Surely the main fan shouldn't come on when it is cold as the engine needs to warm up as soon as possible?
    I've replaced the thermostat housing, thermostat and the 2 sensors on the thermostat housing with no luck.
    The car drives fine although the temp gauge sits a tiny tiny bit to the right of 12 o clock. "
    Thanks in advance!
    Jamie
    Nov 2012
    34
    Sounds like the temperature sensor for A/C if you ask me.
    If the control unit isn't getting plausible reading from the temperature sensor then it'll bash both fans on default to "cool" the condenser.
    Sounds a bit like too much of a coincidence if they don't come on when the climate control is off.
    Regards
    Chris.
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Does he have AC?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    JD09's Avatar
    Dec 2009
    3,080
    Thanks Chris and Steve. I'll ask about the AC.
  1. coolant fans come on with the air con ?
    By matt e in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2011, 16:42
  2. Fan coming on when cold???
    By locost47 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2010, 17:59
  3. Engine fan coming on randomly - A3 2.0FSI
    By James_Solihull in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 16:55
  4. Radiator fan comes on & stays on!
    By madpirie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2009, 19:36
  5. 2.4 30v - Electric Radiator Fan never coming on...
    By MrJoshua in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2007, 11:30
