AH FabricationsVolks Autos
Results 1 to 13 of 13
    Oct 2012
    238
    Long travel on brake pedal after bleeding.. Help!
    So i took the calipers off and renewed the brake fluid on my S3 the other day. Unfortunately one of the clamps came loose and it pissed all the brake fluid out over night . So topped up the reservoir and bled the brakes using an pressure bleeder. The brake pedal still have more travel than it should of so i bled the brakes using the 2 person method (one on the brakes one on the nipple). Seems ok when the engine wasnt running. Fired it up today after getting it out of the garage and there is loads of travel. Its not spongy, just has a lot of travel, not so far that it fits the floor, but almost!
    So i heard something about bleeding the master cylinder if you run the reservoir dry, but dont know where the bleed nipple is/how to do it?? Also heard that you need vagcom to bleed the master cylinder or something :S?? Help please!
    Sep 2012
    Matlock
    44
    You've probably got air in the ABS pump. Pain in the arse to sort, but you just need to keep bleeding it through. Get some one to pump the brakes, then undo bleed nipple, and repeat.
    I assume you're starting at the furthest point on the car, and working round?
    Oct 2012
    238
    Which bleed nipple are you talking about? The one on the master cylinder??
    I did yeah.
    Sep 2012
    Matlock
    44
    Bleed nipple on the callipers.
    If you've let the system run dry you'll get air trapped in the ABS pump, so you've just got to keep bleeding it through till its gone.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,109
    I think there's 2 bleed nipples on the master cylinder, you need to do them both before doing the rest of the system.... you may also need to cycle the abs pump using vag-com depending on how dry you let it get, also don't over preasurise your ezibleed by using a fully inflated tyre as this closes some valves inside the ABS pump and stops it bleeding properly..... they are an absolute pain to be honest and i was never happy with mine though they past the MOT no problem.... good luck
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Oct 2012
    238
    Ta guys. How do i get to/where are the bleed nipples on the master cylinder? And how do i bleed it? Thanks
    chaz20vt's Avatar
    Aug 2012
    425
    Re: Long travel on brake pedal after bleeding.. Help!
    Just commented on this on Sw dubs so ill keep me eye on this
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Quote Originally Posted by Rice View Post
    same as the calipers??
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Mar 2008
    Oldham, Manchester
    1,109
    As Bill says.... they are just the same as doing your calipers..... they can be quite hard to see but they are on the master cylinder just under the fluid reservoir if i rember they can be quite tricky to get a spanner on and access is harder on the S3 than a normal A3
    Jun 2004
    Surrey, UK.
    269
    I prefer to use a mityvac, its a vacuum pump that sucks the fluid out. I find it a lot easier to use than the ones that use the spare tyre to pressurise the system.
    Mityvac Brake Bleed Kit
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I had this issue a few weeks ago when fitting and bleedin brembos and it was due to not enough pressure in the spare tyre I used with my Ezibleed kit. If you're bleeding like this, make sure you have 20psi in the tyre.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Oct 2012
    238
    Thanks for the replies chaps! Bled the master cylinder, clutch and brakes last night and it's much much better!!
    Oct 2012
    238
    i was referring to what sequence I should do it in, as there are two.
  1. Long travel in brake pedal .. Help
    By CheekyAudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2011, 15:54
  2. Brake Pedal Monitoring Error HELP HELP
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2010, 23:11
  3. Long brake pedal travel
    By <tuffty/> in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 19:32
  4. No brake pedal after caliper change
    By dnLcal in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 12:40
  5. Brake pedal travel after brake upgrade!
    By Stevie C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2008, 17:48
