Badger5Chris Nott
Results 1 to 7 of 7
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    nsr tyre wearing on the inside?
    Noticed it when I got q nail taken out of my tyre.anyone know what it could be?I had my rear beam bushes replaced for powerflex bushes about a year ago but I'm not sure what it causing it.anyone had this?
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Feb 2012
    Peterborough
    Your car properly needs a alignment.
    Once the wear has started you cannot stop it, you would be best putting 2 new tyres on the axle then finding your local garage with a Hunter alignment machine then they can Set you car up to manufacture spec or to any other spec also give you a print out of before and after. If you cannot find a hunter machine then make sure its a 3d alignment. This is what I did and it stopped my tyre wear.
    I use a garage in Peterborough called Monarch Automotive after reading a good review on this forum worth a search for your local garage.
    Hope this helps
    JackS3
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    negative camber or toe in?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    That would be negative camber or toe out...
    Any chance its lowered without adjustable tie bars?
    Maybe a broken spring on one side if it isnt...
    ...... Now this one's MUCH better!...
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    guys,
    Marty has a golf, the rear is 100% non adjuatable.
    Marty: I'd get yourself down to a tracking place, and have the back end checked out. If it's within factory specs it shouldn't wear. Perhaps your beam is a bit out....
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Sorry its a golf as prawns said.
    I got it aligned a few months ago and I'm beginning to wonder what was actually done as im sure its been there a while? I'll get the a different garage to check over it,new tyres while in at it.
    Word!!!
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Paradox did you get to the bottom of your tyre wear? I've just notice mine is wearing on osr inner edge, not to sure what step to take next
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
  1. Inside Tyre Wear?
    By tyrrelll in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2011, 16:04
  2. Hi all i have a MAYOR issue with inside tyre wear...Need help URGENTLY..
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2011, 18:37
  3. Inside tyre wear on -40mm lowered C5 A6
    By evomaster3000 in forum Handling
    Last Post: 26th March 2007, 16:48
  4. Rear tyres wearing on inside edge
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th February 2007, 19:35
  5. Help - Serious wear on the inside edges of front tyres.
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2006, 15:36
