Perfect, that's the type of figures I'm hoping to achieve just now need to do some research and start my shopping list to active it lol
Shopping list is...
Jetex filter (order from Bill @ Badger5)
3" downpipe and decat (eBay)
Backbox if you fancy it
Forge 007p (eBay)
Generic silicone turbo intake pipe (eBay)
PCV delete items and a catch can
N249 bypass
Make sure the cambelt and water pump are done, PROPER service and drop the sump to check the pickup pipe/replace.
THEN stage 1.5 mapping to get 220bhp.
S3 312mm brake upgrade.
Eibach/Whiteline rear anti roll bar kit
Coilovers (-£200 ones on ebay)
eBay special turborevs/toyosport FMIC (eBay)
Forge MAP sensor tube.
Coldside DV relocation kit and spring set (needed to fit FMIC)
Loads of vac' hose so you can replace all the leaky **** under the inlet
OEM K04001 actuator
VR6 clutch and G60 flywheel
Stage 2 mapping and fingers crossed 240bhp if your engine is healthy
That should keep you going for the next 12 months. Good luck.
