Sky InsuranceChris Nott
    Apr 2012
    17
    Strange brake light warning beeping
    Hi,
    Bit of a strange one so bare with me.
    Just recently when pulling away in traffic the car started beeping at me (single beeps) to which I've narrowed down too...
    If the head/parking lights are turned on the "Brake light faulty" symbol appears. If I apply the brakes the warning symbol goes, but comes back with a beep as soon as I release the brakes.
    If the head/parking lights are turned off all is fine. When I apply the brakes for more than about a second I get a beep and the "Bulb failure: dipped headlights or rear lights" symbol comes up. As soon as I release the brakes the symbol disappears.
    I drive in London traffic every day and as you can imagine, it's fffing annoying :D
    I've done a walk around and all lights are fine, including the brake lights.
    Any ideas greatly appreciated!
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Are you sure it's the bulb warning light and not the worn brake pad symbol? Looks a bit like (O) symbol.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Apr 2012
    17
    yeah sure, it's "Bulb Failure" and "Brake Light Faulty" it's the bottom two in the first column
    Apr 2012
    17
    Just to add a bit more to this.
    When the parking/headlights are on the brake lights come on!
    I pulled the fuse for the brake lights (13) and with parking/headlights on brake lights don't come on.
    I can't seem to find a good wiring diagram, but does anyone know if this means the issue is before or after the switch?
    Apr 2012
    17
    The plot thickens
    2 more things
    When I apply the brakes the front left parking light comes on.
    When I turn on the parking lights all three rear brake lights come on, applying the brakes makes them brighter.
    Removing the front left parking light makes no difference.
    So seems I have a short between the front left parking light and the brake lights.
    I'm guessing it's going to be somewhere under the dash given the affected lights are at opposite ends of the car.
    Anyone with experience of the wiring hazard a guess where it could be before I start poking around?
    Apr 2012
    17
    If anyone is interested this was driving me nuts, another symptom was when driving if I turned the lights on the accelerator signal completely dropped and sent the engine to idle until I reapplied the accelerator, very nasty on a motorway at speed.
    Anyway should have just did what so many other threads recommend and just replaced the bulbs.
    I thought they must have been ok because they were working and that there was short somewhere in the wireing.
    Pulled the bulbs out and the brake lights/rear driving lights are a single dual filament bulb.
    Turned out rear drivers has one broken filament that would drop and touch the other below while the rear passenger one of the the top filament "legs" had dropped and was shorting the one below.
    £4 to replace and no more warning beeps every time I apply the brakes!
    :D
  1. Intermittent centre brake light warning on DIS!
    By Abb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th September 2013, 23:16
  2. Strange "Brake Pad" warning light.
    By A1an in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2011, 12:01
  3. Brake light warning symbol
    By dougie175 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2011, 12:57
  4. centre brake light warning
    By madphil in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd July 2010, 07:21
  5. air bag light on and faulty brake light warning on dash ?
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th March 2010, 17:45
