EM TuningVolks Autos
Results 1 to 7 of 7
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Anyone help please?
    When I'm on half throttle it sounds like the dv is going off permanently until I put my foot down more and when I take it off doesn't dump very loud, could this be waste gate problems?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Could be, also could be the DV sticking open prehaps?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    No i doubt it very much.
    I had this same problem when there was a hole in the seal of my cone filter. check that first. If thats fine then check you DV is between the tip and the hard pipe and tightend up. thats what i would check first
    sounds like there is a leak somewhere and in my experience that was where the problem was
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Thanks guys, dv is a 008 3 months old filter is Jetex 2 months old so hope it's neither! How do I check is not the dv sticking?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    take the DV off and (not in a rude way,get your minds out the gutter lol) put ur finger in the bottom of it and push the piston up and down. it should move without much pressure. if its a new valve I doubt it will be sticking already. open the DV and check that it is well lubricated. as for the jetex, take it off and check around the rubber connector as this is where mine split. Im not sure if you have the old one or the new revised one as the old ones were prone to the rubber splitting when tightening them
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    DV won't be sticking... you've just done an N249 bypass yes? as long as thats correct then the noise is most likely that you have to strong a spring in the DV... fit a green spring if not already...
    With the engine on idle, pull the vac pipe from the top of the DV and stick your finger over it... it should be sucking/get stuck on your finger... if not then you have done the bypass incorrectly
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    548
    It was doing it before the bypass, I havnt looked what spring is it there, the standard one, I have in the box a blue and yellow so presume its the correct one in use?
    Thanks for the help btw
  1. CD Error - Can anyone help please???
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2009, 16:47
  2. Can anyone help please?
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2009, 16:51
  3. S3 Mirror Glass - Can anyone help....please?
    By S3PEG in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 09:32
  4. Anyone Help Please ???
    By ANNANBHOY in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2008, 18:24
  5. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
