take the DV off and (not in a rude way,get your minds out the gutter lol) put ur finger in the bottom of it and push the piston up and down. it should move without much pressure. if its a new valve I doubt it will be sticking already. open the DV and check that it is well lubricated. as for the jetex, take it off and check around the rubber connector as this is where mine split. Im not sure if you have the old one or the new revised one as the old ones were prone to the rubber splitting when tightening them
