I have followed the guide in the stickies but as mine is a preface lift ajq code Quattro it does not have a Sai or n112... Am I right in sayig I just put the vac hose from the inlet mani to the dv? Can someone infirm this please
Essentially yes... all the DV requires is a vac pipe from the inlet to the top of the DV... not familiar with the plumbing on yours but just make sure there are no check valves etc left inline...
