Chris NottBadger5
Results 1 to 7 of 7
    Mar 2012
    10
    Possible oil pump problem A3 1.8T
    Just on the way home from work today and my oil pump seems to have failed, Ive been seaching this forum and the net and have gathered that this is most likely the problem. Basicly as i came off the motorway and my oil light starts beeping 3 times and have a large oil light warning on. Ive also got a fairly loud ticking noise coming from the head on the engine. What im wondering is what parts will i need to order? Just the oil pump itself? Should i check anything else first, could there be a clog ect? And is it safe to drive the car like this, or could this result in oil stavation and engine damage?
    Any help would be appreciated.
    Car: 2001 A3 1.8T
    Mileage: 105000
    Thanks Jack
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Do you have to ask if it is safe to drive as is??
    probably the infamous blocked pickup...if you are lucky and stopped immediately you MAY be lucky...
    Obv dont turn it over dont drive it ... it needs the sump taking off at the very least and see what the problem his...
    Mar 2012
    10
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Have you even checked the oil level? If not I'd suggest that first.
    Sorrry to say, but if it was making bad noises then I'd say it's already damaged.
    Most likely the hydraulic tappets siezed.
    ...... Now this one's MUCH better!...
    Mar 2012
    10
    yeah the oil is spot on, guess the sump will have to come off and see what damage is done from there
    IFFY_77's Avatar
    Jun 2012
    London
    68
    I had this problem few months ago, big pieces of my dip stick had broke off and made it through to the oil pump also oil pickup was blocked but was to late damage was done. I had to get a new oil pump and I changed all 20 hydraulic lifters due to ticking sound and did rocker gasket as it was leaking a little from before. Oil pickup was cleaned up with the help of the trusty air gun. what a nightmare a little dipstick can cause. But the ticking is most likely dried up lifter/lifters.
    Damage report: Lifters £12 each oil pump £80ish if I can remember right.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    search the oil pick up pipe
    blocked no doubt.
    dont drive it until you get this fixed
    it will ruin the engine if driven..
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  1. Replies: 74
    Last Post: 17th April 2014, 00:16
  2. Oil pump problems
    By chris67 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th October 2012, 17:42
  3. A4 1.8 Turbo 150BHP oil pressure problems
    By imported_Donald_MacIver in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd September 2005, 07:23
  4. Oil Pump 5 cylinder Engine
    By imported_Vinnie in forum Classic Audi Forum
    Last Post: 26th February 2005, 18:33
  5. Fuel pump problems
    By nunzio42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 12:09
