Monster MotorsportEM Tuning
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    keeps blowing off
    anybody had any problems with intercooler to inlet manifold samco/ silicon hose blowing off, mine seems to do it about every 6 months or so, most embarrassing, also seems that there is oil inside the hose (poss due to recirculation), so have thought about fitting some sort of oil catch tank instead. any thoughts??
    PaulS3's Avatar
    UK
    988
    Re: keeps blowing off
    clean inside of hose with solvent, ie electra-clean, meths, or white spirit, and the hose tail. end.
    re assemble.
    since i fitted samcos and decent hose clips i havent had a problem.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Is there any way to tell it has come off ie apart from the lack of power? Is there a noise etc...
    Just would be difficult to see if it has blown off behind the bumper!
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Andy,
    I got a catch tank off of ebay for 35 and fitted it. easy job and definately worthwhile as so much oily gunk gets sucked back into the intake!
    PaulS3's Avatar
    UK
    988
    [ QUOTE ]
    [/ QUOTE ]
    Jam Dont worry its really obvious.
    the huge Woooooosh pofffffff when it blows, the lack of power and the increased wheezy noise from the turbo thats now leaking to fresh air.
    you cant miss it.
    fave one is off the steel pipe to first intercooler, top end.
    bottom end is a pig if it goes, its a bumper off and headlight out job to get at it.
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    Cheers Rich, does it just connect to TIP and you empty it yourself ?
