Sky InsuranceChris Nott
    Feb 2004
    Middlesex
    79
    Power steering warning on DIS
    Hi, I have what i believe to be a power steering fluid warning sign come up on the DIS (it is a circle with 3 dashes around each side), i toped up the power steering fluid but it did not clear the warning, It didn't look like it needed toping up but i added a little anyway.
    Anyone any ideas what this could be? is there a sender unit or somthing that could be at fault?
    Chris
    Aug 2003
    Scotland
    22
    Re: Power steering warning on DIS
    I believe its the brakes you need to look at!
    Feb 2004
    Middlesex
    79
    Here is a pic of the warning
    Is this brakes or steering?
    Oct 2003
    South Wales
    2,942
    Thats a warning telling you that your brake pads are low...
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    brakes
    Feb 2004
    Middlesex
    79
    Hmmm, ok thanks. Looks i better get some new pads as i'm going to the 'ring again next weekend.
    Tempted for a set of Ferodo 2000..
