AH FabricationsJMB Retrofits
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Alex C
Thread: Tech advice needed regarding S3 8L
    Oct 2012
    Leicester (LESTA)
    57
    Some of you may have recently seen my thread about the engine temperature etc and would just like to add that vehicle is all running well now after having changed the thermostat and coolant temp sensor. I've currently booked myself in to get a custom down pipe made on monday. I've owned about 5 subarus in the past (2 non turbos) and 3 turbos (wrx x2) and classic version 6 sti however I the reason why I didn't get a jap 4wd turbo this time was basically because I was after something a bit more 'quiet' and most importantly stealth (power but without the attnetion) also power with comfort rather than raw power, stupid mpg and headaches cruising down the m1. I remember my scoobies use to pop and bang even the non turbos and I really wanted that effect on the S3. I remember having a 'bee r rev limiter' installed on my last scoob which was also known as a '2step rev limiter' as it use to POP AND BANG LIKE MAD!.
    I did do some research via google and revealed something like a 'WOT box' which to my knowledge has flat foot shifting (similar to antilag) however reading some of the feedback, I heard they caused engine failure etc. I would like to know is it possible to fit an ignition cut rev limiter to my vehicle ? 2002 S3 AMK
    It would be something ideally like this
    BEE-R REV LIMITER TYPE H HONDA CRX CIVIC INTEGRA | eBay
    or
    OMEX Clubman Rev Limiter Twin Coil | eBay
    Other options I can think of would be an aftermarket ecu with anti-lag enabled however I am not looking to install this type of thing on the S3.
    Any help would be most appreciated
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    you've really bought the wrong car for that sort of thing.
    tuned highly and a well selected exhaust and you can have pops and flames without these devices.
    for a wot box you should be looking at a forged engine. they do as they say, wide open throttle and hold boost, so they are quite extreme.
    i've never seen an ignition cut device before but reading about them i think the idea is sound. so that could be an option.
    another option would be to speak to a reputable tuner, there are lots of them, who offer launch control and flat shift as part of mapping (on the standard ecu), i've seen the launch control popping and flaming. Also, speak to the tuner about whether they can map in ignition cut. i think that is your best option for what you want. obv a full exhaust system will help things, ALOT.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,451
    I have a wot box if you want one
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    S3 Paul's Avatar
    Oct 2006
    2,764
    Personaly i think Anti lag makes for massive heat build up in the turbo??
    The K04 is a poor little thing that gets to temperatures close to that of the sun without such systems.
    Personaly i would steer clear, More heat = shorter life span
    Noggy Blue 2001 S3
    RIP S3dave
    May 2004
    nr Glos
    7,131
    expect it to break
    you got out of scoobys because you wanted something quiter and more refined............. then in next breath want pops and bangs.
    s3's are too cheap now
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Essflee's Avatar
    Mar 2008
    2,007
    Yup :-(
    revo'd
    Essflee's Avatar
    Mar 2008
    2,007
    thought the same
    revo'd
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    i went in a car with a wOTbox at the weekend, and I didn't like it at all.
    My car is reasonably highly tuned, and with a hot exhaust, it pops and burbles a lot, and spits fairly reasonable flames on over run and on the dyno, these arn't mapped in, or 'on purpose', but just a characteristic of the hardware.
    The car with the WOTbox didn't pop or bang, it was a genuinely violent explosion, and didn't feel like a result of tuning at all, just an artificially created BANG, not a byproduct of a highly strung engine, I'll be honest, I wasn't too keen on it, it just sounded like everything was going to break.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    ...not to mention he blew the crap out of his back box on the way back from the dyno day...
    Not a fan tbh... flat shift and launch control can be mapped in if required to the ECU
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,131
    <tuffty/>
    and apparently bent the actuator rod!!!
    thats a whole lot of EXPLODING going on..
    eak!
    bill@badger5.co.uk
    Jun 2012
    57
    <tuffty/>
    Really? Is it possible to map a launch Control function to the ECU? Didn't know that!
    Would be possible also on our old cars?
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Quote Originally Posted by Golfer1991 View Post
    apparently a man walked on the moon in 1969!!
    Big Bang Yam likes this.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    Quote Originally Posted by Alex C View Post
    haha, yea, APPARENTLY
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    Re: Tech advice needed regarding S3 8L
    They did I was there, no biggie, they all got kinda gay over it... Started kissing each other on the moon.
    I was like Pfft I'm having nothing to do with this, hence the reason my name has nothing to do with the moon landing..
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by coatesy View Post
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    WOT boxes are also known to destroy lambda probes and CATs due to the excess unburnt fuel...
    <tuffty/>
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    ah yes, I think Simon has done 3 lamda sensors since fitting his WOTbox!
  1. URGENT ADVICE NEEDED/WANTED REGARDING COOLANT/HEATING IN TDI A4!
    By polo10v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st October 2011, 21:47
  2. Advice Needed Pls
    By RAV in forum Diesel forum
    Last Post: 25th February 2004, 11:56
  3. Advice needed on changing
    By Mike_Wales in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 14:07
  4. A3 / S3 advice needed
    By MsK in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2003, 11:38
  5. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
