Sky InsuranceAH Fabrications
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    Knock Sensors and Timing Pull
    Background:
    Standard Engine S3 8L AMK
    Fault Code: EGT sensor - being fixed next week
    Rattely clacking head: I think this is either cam chain or tappets - hopefully being fixed Wednesday next week
    Anyway, today i went out and logged it, i didnt do any hardcore 100% load 0-redline pulls just drove it around normally in traffic in and out of town logging.
    I knew already i was suffering from timing pull so i logged [003, 026, 020]
    block 26 are the knock voltages and block 20 is the timing pull block
    Here is a plot of timing pull against engine speed:
    so its cylinders 3&4 that are getting timing pull
    But when plotting the knock sensor voltage against engine speed:
    it is the knock sensor on cylinder 2 that looks abnomal
    Am i right to be confused here or should i just travel hopefully?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    knock voltages alone dont tell the picture..
    CF correction resultant accounts for the windowed knock regitration not just voltages.. which swing about a lot... I've seen 30v! and no CF
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    thanks Bill,
    I know i don't have the logs posted but what might cause timing pull only on cylinders 3&4 on part throttle?
    Alex S3 AMK
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    if you have an egt fault wont your fueling be abit off.
    mine was, i was very rich for quite a while.
    That fault might have something to do with your CF. just a thought, but once its fixed then do your logging again to see if there is any change.
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    Thanks Karl. yeah i will do, i am hoping that either the EGT or renewing the timing chain will fix it but i figured that both of those faults would affect all four cylinders rather than just the two.
    Maybe its tappets on those cylinders or maybe both of them coincidently have problems with piston rings?
    Alex S3 AMK
  1. G61 and G66 Knock Sensors
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2012, 20:40
  2. timing pull. what is a little and what is a lot
    By Matt82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2010, 16:50
  3. MAF and knock sensor problems??
    By <tuffty/> in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 12:13
  4. ARB and timing chain - at only 36k ???
    By Amchlolor in forum TT/TT-S/TT-RS Forum
    Last Post: 16th August 2006, 15:46
  5. What can knock a knock sensor?
    By MisterD in forum General Technical / How To
    Last Post: 20th May 2003, 13:53
