Monster MotorsportBadger5
    Oct 2012
    57
    Corroded Chassis Sill
    Hello All,
    New to owning A3 1999 noticed one of the sills is corroded no holes but want to get it sorted, is it a case of getting body shop to cut off old one and weld new one in? Can these sills be bought anywhere? and if so where can I get hold of one? (part number etc)
    Many Thanks
    Jason
    Lewis583's Avatar
    Mar 2010
    870
    Sometimes providing the corrosion isn't too bad, it can be linished back until clean metal is found. Then treated with an anti-rust agent and painted over the top.
    However if the corrosion has made the sill too thin you either one of 2 options. Have the bodyshop cut out the affected area and have them patch a new piece of steel in it's place. If done to a good standard you won't be able to tell it has been patched. Other option is to have the bodyshop put a complete sill on it.
    Repair panels/sills can either be gotten from main dealers or a motor factors. Though if you are getting a bodyshop to do it, it would be far easier to just let them sort it.
    It would also be better to stick to one thread instead of creating numerous ones about the same issue.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. Aluminium Sills
    By imported_RedSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2004, 16:19
  2. New B7 chassis Convertible?
    By imported_ndrummond in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2004, 20:05
  3. A3 Sills
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 11:17
  4. painting black side sills possible?
    By ha3t in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 21:26
  5. Has anyone upgraded a 2002 A4/(B6 chassis) ?
    By Dang324 in forum In-Car Entertainment
    Last Post: 18th June 2003, 19:46
