Sky InsuranceBadger5
    Oct 2012
    aberdeen
    120
    Crank case breather
    Folks need some help can someone post link to where I can buy crank case breather hoses. As think I've found the cause of my miss fire.
    need urgently as we'll
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    TPS or a dealer mate... not knowing what car you have (as you have not posted this info you will find the part numbers on the parts themselves (gentle cleaning will help too)..
    Here is an image of the parts for an AMK/BAM S3 as a guide (PN's should be the same on the bits shared across engine codes)
    <tuffty/>
    Oct 2012
    aberdeen
    120
    It's the 1.8t aum code. All these parts same across the range then. I'll call specialists tomorrow
    thanks
    Oct 2012
    aberdeen
    120
    Is it possible to reset the engine light without a diag machine
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Most of the parts are the same but most of the extra pipes in that pic are for S3's not AUM A3's... the air pump should be the same as is the PCV elbow but normally you can give them your reg number and at least one of the PN's from your kit and they will find all the bits you need... (don't just order the bits in the pic without verifying they are the right ones for your car)
    If the CEL is on then ideally you need a diag tool to see why rather than just turn it off... there will be a reason for it being on and its kinda a good idea to find out what that is...
    I suspect considering the state of your PCV pipes its an adaption channel code (exceeded adaption or similar)
    <tuffty/>
  1. crank case breather
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2010, 19:22
  2. 1.9 TDI crank case pressure (youtube clip)
    By johnmccracken in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2009, 14:39
  3. normal crank case pressure
    Last Post: 4th August 2009, 01:15
  4. Crank case oil seal
    By aldi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 21:46
  5. breather assy.
    By infinitiheli in forum General Technical / How To
    Last Post: 9th October 2003, 19:14
