Badger5AH Fabrications
Like Tree1Likes
  • 1 Post By vfr800
Thread: S3 Headlamp Adjuster Removal / Refit
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi,
    I just did a video showing how to remove/refit the electric adjuster on the S3 facelift headlight unit.
    It's the same for the A3 halogens I believe - dunno if it applies to other models.
    Show's how to do it with the light unit sitting on your lap but it's just as easy to do with it in the car.
    I really just wanted to show how simple it is to do without any force or damage to the clips.
    Hope this helps someone.
    Liam
    Filth likes this.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Thanks Liam for sharing this information as it will be useful to others. x
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    220
    Thanks Liam, handy thread this is, ou dipped headlight beam lands about 6 feet in front of the car so definately needs adjustment of some kind, on my now ex S4 Cabrio it did a headlight height search/ adjust whenever the lights where turned on.
    Regs Rich
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    You might find you can take the adjuster apart and fix it.
    I took my old / dodgy one apart and found there were some contacts that weren't seating properly. Very easy to fix if that's the problem.
    Liam
  1. 8P side indicator remove/refit
    By ByronM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2009, 09:02
  2. Suspension Removal/refit??
    By orion1210 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 11:53
  3. Headlamp adjustment
    By Halfpint in forum TT/TT-S/TT-RS Forum
    Last Post: 14th February 2008, 08:29
  4. LHD/RHD Headlamp adjustment *URGENT*
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2007, 11:05
  5. Removing/Refitting S3 turbo
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 09:44
