Volks AutosEM Tuning
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    Lambda Sensor / O2 Sensor Replacement?
    Hi, I have an APY s3 which only requires 1 Lambda Sensor (pre cat). Im trying to shop around to find the best deal on a new unit. My local Auto Factors can supply me with the required part for about £40, the only issue is this is a Febi part and not a bosch. My local TPS have Quoted me £120 for a new bosch unit (part number 02580060332).
    My questions is: is it essential that i buy a bosch unit over the Febi part? does any1 have any views on this please?
    Audi S3 APY.
    Man needs god like a fish needs a bicyle.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Get a Bosch sensor from either ECP or GSF...
    <tuffty/>
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    GSF cant supply a Bosch unit. ECP can only supply me with a Bosch unit where i have to manually wire it in myself. is this easy to do?
    Audi S3 APY.
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    I can get an NGK unit (direct fit) for £75. ive always used NGK on my MotoX bikes and found them to excellent and very trustworth parts, but again im unsure when compared to a bosch unit.
    Audi S3 APY.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Dubstep View Post
    Buy a Bosch one from ECP. Is it easy to do? Yes - if you don't want to solder just use crimp connectors and stash them behind the heat shield.
    For an extra bonus use the discount code UKMK425 to get 25% off.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
  1. Lambda sensor/oxygen Sensor
    By GemmaLouise in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 12:36
  2. Coolent warning light and sensor, easy to replace sensor
    By MingeBlue in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2011, 14:21
  3. Cam sensor/crankshaft sensor
    By crawleyguy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th January 2011, 13:45
  4. MAP sensor & MAF sensor.
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2010, 08:39
  5. Audi S6 rear parking sensor question about replacement
    By technics100 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2009, 14:33
