Sky InsuranceJMB Retrofits
    Apr 2011
    Dublin, Ireland
    614
    D/S window not working properly
    Since yesterday the drivers side window will not work properly anymore. I now have to hold the button in order to raise/lower the window. The passenger side still works fine. Any ideas on what is causing this and how it can be fixed.
    Dave.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,477
    with ignition on hold the drivers side window button in the 'up' position for at least 5 secs.... onetouch should be restored.. this normally happens if the power supply is interrupted (battery disconnected for example)
    <tuffty/>
    Apr 2011
    Dublin, Ireland
    614
    Worked a treat. Thanks.
  1. Indicators not working properly
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2009, 08:51
  2. Audi remote key not working properly
    By Dracoro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd October 2006, 08:17
  3. Replies: 1
    Last Post: 27th November 2005, 09:39
  4. Latest threads not working properly
    By imported_Yaseen in forum Site Support & Announcements
    Last Post: 20th February 2005, 22:50
  5. pc sound not working properly? Help
    By Dumpvalve1 in forum General Chat
    Last Post: 27th September 2004, 22:26
