EM TuningChris Nott
Results 1 to 7 of 7
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    Failed MOT on emissions, need advice please
    Hi, so my car went for its mot today and failed on its emissions. Ive had the car sorn'd for the past year while ive done some work on it.
    here are my Emission results:
    Fast Idle:
    CO = 1.24 - fail
    HC = 759 - fail
    Lambda = 0.988 -pass
    Second Fast Idle:
    CO = 1.17 -fail
    HC = 296 -fail
    Lambda = 1.146 - fail
    Natural Idle:
    CO = 1.50 - fail
    The car is modded with SS mani, 3" dp, 200 cell cat and jetex exhaust. Ive connected to a VC and no faults are coming up.
    How can i reduce these figures?
    Audi S3 APY.
    Man needs god like a fish needs a bicyle.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    The figures are higher than you would expect with no cat at all on a healthy engine, so i'd suggest you need to be looking at fuelling/sensors.
    Might be lambda or MAF, or a air leak throwing out adaption?
    Have a look at the fuel trims with VCDS.
    TD5 Land Rover Defender build
    RIP S3dave
    May 2004
    nr Glos
    7,183
    ecu can only control its lambda....
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    Ok, so ive got a brought some things to try and fix my issue:
    Plugs
    Fuel filter
    Wynns Clean burn
    Should i be looking at getting a new lambda sensor (apy so only have 1 sensor)?
    Also ive noticed that it might be running rich as the mpg is bad and there is a faint smell of fuel in the engine bay when engine running, would putting the original airbox back on then restrict the amount of air therefore lowering the ratio?
    Audi S3 APY.
    RIP S3dave
    May 2004
    nr Glos
    7,183
    do you have vagcom to check lambda readings
    www.badger5.biz
    bill@badger5.co.uk
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    no :-( only a cheap vc to read/wipe codes
    Audi S3 APY.
    AJC
    AJC's Avatar
    Surrey
    172
    I've had exactly the same problem with the MOT last week. I'm about to connect up VCDS to check for fault codes but think I might need a new lambda sensor. Any way to check Bill if this needs to be replaced?
  1. Replies: 8
    Last Post: 28th March 2010, 00:23
  2. Painting Calipers tomorrow, need advice please.
    By KeepItTidy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2009, 19:41
  3. Gaiter leaking oil need advice please...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2009, 15:02
  4. A4 REMAP need advice PLEASE!
    By missviper in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2008, 10:02
  5. Which A3 To Go For? Need Advice Please
    By emzino in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2006, 17:10
