    Omniquito's Avatar
    Sep 2012
    55
    Oil pressure 3 beeps - STILL! But it's sweet as!?
    Gents, many may have seen my oil pressure mercy posts a little while ago chasing these 3 beeps...
    Anyway, long story short, replaced oil pump, pressure switch and non return valve, replaced pickup pipe and cleaned everything and have moved from a proper oil pressure (noisy top end) problem due to a clogged pickup pipe to a what seems random issue...
    The car runs sweet at all rpm in all gears, no noise, no nothing... No tapping, no knocking... No power loss, Nothing!!
    Just a random 3 beeps oil pressure warning when up to temp when driving really slowly and ALWAYS below 2k rpm... The car doesn't make any noise and ALWAYS clears the warning as soon as u increase the rpm above 2krpm.
    I'm stumped!
    Please help Neil
    Apr 2009
    Preston
    245
    Sump level sensor?
    That was my issue with your above mentioned symtoms.... Replaced this+ went away. However, In the colder months, it kept coming back.
    God knows! Touch wood
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Faulty dash assuming the pressure has been checked correctly via a gauge..The pressure light/Beeps is set to not register anything pre 1500 rpm IIRC.
    I would ground the pin from the pressure switch and try that, if it still beeps it's not pressure related, it's more likely wiring or a dodgy plug in the back of the dash pod. I had similar on my A4, unplugged and replugged it back in and the problem was fixed.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Have you checked the oil pressure in those circumstances?
    Just because you've had a guage on it and it seemed ok, doesnt mean it IS actaully ok once its fully warmed up.
    TD5 Land Rover Defender build
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Years ago I had a bora in with the same problem as yours, we tried a few things no change, we then took it to the dealer no change so I took the sump off and checked the big ends all good then I checked the mains, number 1 main had spun a shell and at a point would lose oil pressure for a split second and then be fine for a few days, the sump was clean as to was the pick up, could be worth checking even if just to confirm its not that mate
    "Stick a V8 in it!"
    15,370
    if you dont want to take the engine to bits, fit an in cabin oil pressure guage.
    That way you can actually see what the pressure is doing when the light pops on.
    If it IS low, then clearly theres a mechanical issue. If its normal, its something electrical.
  1. Oil pressure light flashes in display, but oil pressure is ok, even new sensor
    By Finnie1967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2012, 15:39
  2. Oil pressure light is on & three deadly beeps!
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2011, 22:20
  3. 1.8T oil pressure warning - advice sought
    By imported_CurryMilkShake in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2004, 01:28
  4. Oil Pressure Guage Problem
    By Crossbox in forum Classic Audi Forum
    Last Post: 23rd August 2004, 23:42
  5. S3 Turbo Oil Pressure - How to check
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2004, 09:45
