AH FabricationsBadger5
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    S3 back from 89k service few running issues
    So got the car back to be fair i dont think the issues are that bad.
    1. weak battery (now sorted)
    2. cracked rear spring i'm gonna replace both springs + shocks & bushes
    3. split cv boot
    4. coolant sensor fault & lambda B1 atfer cat B1 sensor fault
    5. fog light switch not functioning correctly
    6. rear washer not working
    I'm not to fussed about the fog switch or the rear washer not working neither of these are used that often anyway.
    My main concern is the sensor faults, the coolant sensors looked easy enough to replace but is everyone going for oem sensors or i can use alterative brands as supplied by euro car parts, GSF & vwspares
    On full boost the car is hesitating i wonder if the lambda sensor fault is thrown up because of the coolant fault & therefore confusing the ECU.
    Anyway any help would be great.
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Dont forget your Fogloght switch problem may become an issue at your next MOT
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Nov 2005
    UK
    1,688
    was hoping for more of a response
    wanted for 8L S3:
    Milltek system
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    rear washer and fog switch need doing regardless for the mot simple as mate!
    along with the split c.v boot and nackered spring, but as you say there getting done!
    your lambda is just screwed into the exhaust so an after market motor factor jobbie will do, its just the fitting thats a pita!, as for the coolant one, i would try for oem if you can imo!
    Nov 2005
    UK
    1,688
    yeah i havent really thought about the cv & rear washer.Tempreture sender to be fitted this weekend.
    What i dont get is my car always hits 90 & doesnt move (the odd occasion it hasnt made it to 90). In the summer the car didnt overheat therefore the thermostat must be working.
    The lambda sensor doesnt of seemed effect performance or mpg. I'm getting 30mpg most of the time which correct for the combined driving do. The only thing i have noticed is under boost it tends to hesitate maybe my sensor just needs a clean, if so what should i use ?
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,688
    fitted a new temp sensor yesterday, the gauge had previously stopped moving & is now bobbing up & down depending on speed, so i assume my thermostat is stuck open. Relatively simple just need to order one up, next up lambda sensors, headlightswitch, shocks & springs
    wanted for 8L S3:
    Milltek system
  1. Car back from the service with a longish list of things to be done
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2009, 19:32
  2. Pulled by police on the way back from service
    By A3NDY L in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th August 2008, 18:13
  3. Car back from Bodyshop fixed with a few extras ;)
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2004, 12:22
  4. Car back from bodyshop - wicked
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2003, 12:23
  5. Just back from Barcelona.......
    By biturbo in forum General Chat
    Last Post: 13th January 2003, 19:03
