81.5mm pistons, what cc would this be?
Dani_B19
Barnsley
As per title, would 81.5mm pistons give a 1900cc displacement or less?
Stickies dude... big turbo info.. 83mm required for 1900 btw..
<tuffty/>
Sorry tufty, i should know better, while your hear, what would 81.5mm be, around 1850cc? Would it esn be worth the hassle?
USING THE STOCK 1.8T BLOCK
With using the stock 86.4mm crank, increasing bore size will give you the following:
81mm bore = 1781cc- stock displacement
81.5mm bore = 1801cc
82mm bore = 1825cc
82.5mm bore = 1847 (small 1.9L)
83mm bore = 1870cc (1.9)
83.5mm bore = 1892cc
With using a 2.0T FSIor 2.0 AEG 92.8mm crank will give you the following:
81mm bore = 1912
81.5mm = 1936
82mm = 1960
82.5mm = 1984
83mm = 2008
83.5mm = 2032
(taken from here... http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/75685-lots-big-turbo-high-power-info.html, which is in here... http://www.audi-sport.net/vb/a3-s3-...info-stickies-please-read-before-posting.html) :whistle2:
<tuffty/>
So for the extra cost and work its not worth it is it?
