Sky InsuranceVolks Autos
    Oct 2012
    sheffield
    do fault codes affect the ECU I.E boost
    Might be a daft question but I've done a vagcom and got
    16486
    16514
    17956
    01423
    I didnt clear them all i know two are from when i unplugged them to see if there was any difference in performance to find the fault.I wondered because I've not cleared thr faults will it run in soft limp mode. its not boosting checked all intercooler clips now.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Scanned but not looked them up yet I see...
    Go here and post the descriptions and links as the codes mean nowt...
    Category:Fault Codes - Ross-Tech Wiki
    The first code for example
    16486/P0102/000258 - Ross-Tech Wiki
    16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    This will cause poor performance.. I'll leave you to look the others up
    <tuffty/>
    Oct 2012
    sheffield
    I have looked but would they really affect boost that much. i read up on running soft limp actuator boost,sounds like me
    Oct 2012
    sheffield
    16486 - maf
    16514 -lamba
    17965 - boost pressure (n75)
    01423 lateral acceleration sensor
    i unplugged both 16486 and 17965 myself with engine running so i thought there are there because of me. I wondered because i have unplugged/re plugged the fault is still there so will it still effect my boost
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    They aren't the vcds descriptions though and posting the proper descriptions help others help you..
    Clear the codea and see what comes back... faults like the maf and n75 will affect performance... you may want to log stuff too
    <tuffty/>
    Oct 2012
    sheffield
    sorry new to this.will do a full description of fault codes next time. fault codes will get took off in morning
  1. Fault code. whats the fix?
    By markfire in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th July 2013, 18:46
  2. Clearing Fault Codes on the Climate Control 'Secret' Screen
    By devan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2012, 13:03
  3. So I get the fault code for camshaft adjuster....
    By Seansy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2011, 19:14
  4. So the S4 saga continues!! Fault codes
    By dsmclark40v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2010, 21:35
  5. Does the ECU really limit boost when cold? at what temp?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2009, 12:45
