EM TuningChris Nott
Results 1 to 10 of 10
    Nov 2011
    138
    What size Jubilee for N75
    hey guys,
    after a bit of advice,
    i have just bought a Badger5 V2 TIP, second hand and there is no jubilee for the N75, i was wondering what size do i need?
    also, the silicon sealant that bill puts on the billet adapter to seal around the turbo, does it matter what type you use(probably a silly question i'm sure)
    thanks,
    James
    Nov 2011
    138
    any help?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    Sealant requirements are documented in the fitting guide (link in the stickies and in Bill Badger5 forum in the sponsors section)... don't know the size of the clip off hand but you could just measure the N75 outlet on the TIP and get one thats suitable?
    <tuffty/>
    Nov 2011
    138
    thanks tuffty
    i can see anywhere mentioning the sealant spec?
    im afraid i dont have the TIP to hand and wanted to go grab the clip today if possible. just on the off chance someone may know the size.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    Give Bill a call...
    Tel:01453822880, Mob:07976 800775
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    May 2010
    Bedford
    2,877
    ETKA says 8-12mm?
    I also used the same sealant as Dave although got the 500degree option just because it was available at local factors lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Nov 2011
    138
    cheers for the replies guys,
    I guess if ETKA says 8-12 that probably right?
    unless it is different sized on the silicon TIPs due to the extra layers?
    would this stuff do the job then?
    Halfords | Loctite 5920 Premium Silicone Copper Gasket Maker/Sealant
    Thanks again,
    James
    May 2010
    Bedford
    2,877
    It probably would be bigger due to thicker piping yeah. I`d perhaps get a couple if you can get singles instead of packs.
    That silicone should be alright. High temp silicone sealant is much the same it seems.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,586
    RE:N75 Jubilee, use a small cable tie unless you are OCD! It's not going to pop off under boost pressure or anything where it's positioned I think?
  1. what size Allen for rear brake?
    By MrTackalakalaka in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2012, 16:29
  2. What size tyre for stretch and best choice tyre?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2011, 17:42
  3. what size tyre for standard 1.8t sport A4?
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2010, 10:48
  4. What size spacers for 19" rims??
    By amoani in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 14:41
  5. what size speakers for an a4 b5
    By Ali A in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 16th May 2006, 17:59
