JMB RetrofitsSky Insurance
Results 1 to 14 of 14
Thread: Knocking noise.
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Knocking noise.
    Hello,
    My 2001 A3 1.8T has developed an annoying Knocking sound/Feeling which seem's to be coming from the passengers foot-well.
    It only really happens whilst going slow over bumps, pot holes etc Nothing when on a smooth road, nothing whilst turning full lock left or right forward or reverse.
    It is really bugging me know as it can be felt through the floor and by my feet. It is something i really would like to rectify myself and sharpish as it is the only thing letting the car down at the moment.
    Any help would be greatly received.
    Kind regards,
    Neil.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I had the same issue, Seemed the exhaust bracket after the Cat was loose.
    Cheers,
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    That's exactly what i was thinking maybe a perished bracket, i will have a look shortly hope thats the issue as its one of the cheaper fix's. many Thanks.
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Well i managed to just about squeeze under the car today and the exhaust seem's solid. Luckily i am booked in with Newton Abbot Audi to get my coil recall done and they have very nicely said they will get it on the ramps and have a look for me. I am very impressed with Audi's after care even on a 51 plate car they are willing to help.
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Another common issue with the knocking seems to be anti roll bar bushes and the top mounts, both are fairly straight forward to do
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Oct 2012
    64
    If its the exhaust bracket i just used a u clamp to clamp around exhaust and old bracket. Well cheap and easy.
    However i have had knocking after fitting new springs. Turns out there should be plastic holders at the bottom of the springs. Old ones were obviously long gone and the springs rusted to the bottom. New ones added
    Feb 2006
    Lincolnshire
    719
    Don't forget the drop links too, they can be a good source of rattles! You need to try and check them in a loaded position if you can, they sometimes appear solid when extended as the ball is sitting in an unworn bit of the socket, if that makes sense?
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Thanks for that, Well i went to Audi today for my coil recall (They were fine) The nice chap had a road test and had a look at what may be causing the noise and says "suspect Anti Roll Bar". A few people have mentioned this so would seem the likely culprit. My question is what would this mean? Is it a case of buying new bush's for the whole ARB?
    Many thanks.
    Feb 2012
    bedfordshire
    748
    Just be new bushes mate will not need a new arb, I had a knocking sound turned out to be the rear bush on the front wish bone was knackered
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Brilliant, thanks for that. Is it a big job or straight forward?
    Feb 2012
    bedfordshire
    748
    Easy job mate
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Cheers fella, does anyone know the correct bushes for my model? I only ask as there is loads of brands ect?
    Oke Phill's Avatar
    Mar 2012
    147
    Just a thought, but get under your car and check your sub frame bolt under the passenger floor well has not come lose. Mine did and it caused exactly the issue you are having, may be a easy fix.
    Thanks Phill
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Thanks for the heads up, got to be worth a check.
  1. Knocking noise !
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2005, 16:02
  2. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
  3. knocking noise
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2004, 23:26
  4. CLUTCH KNOCKING NOISE
    By imported_cudwuss in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 19:43
  5. Knocking Noise
    By L1ARR in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2003, 17:19
