AH FabricationsVolks Autos
Results 1 to 33 of 33
Like Tree2Likes
  • 1 Post By phil miller
  • 1 Post By Prawn
Thread: A3 1.8t AGU Downpipe Fitting Woes
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    Evening all,
    Had an unsuccessful morning trying to fit my new decat downpipe, I've only got ramps so couldn't get enough purchase on the bolts.
    I've got a mobile mechanic coming to look at it, he has a 1.8t Golf and advises me that sometimes the studs can shear/snap meaning a turbo out job to sort this. What's the likelihood of that happening? I did hope this would be an easy job for me to do but I've fallen at the first hurdle!
    Rob
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Get the gas on the nuts and undo them while they are nice and hot, they will never snap off doing it this way mate, or anther way is start the engine and run it up as that will help aswell to undo them
    JudderMan likes this.
    Oct 2012
    Scotland
    237
    Re: A3 1.8t AGU Downpipe Fitting Woes
    Cheers, will let it run for a while to heat them up then, fingers crossed I don't have any problems
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    access from drive on ramps shouldnt be a problem either, I've always done them on my drive and never struggled too much.
    Running the engine to warm them can help, but it'll also make the downpipe red hot and make it much more tricky to get to it without burning yourself!
    Oct 2012
    Scotland
    237
    Cheers Prawn, I'm going to see how this mechanic guy gets on, I've got so much to do on this car I'd rather just let someone else do it and I can get cracking on the rest of the stuff. Never buying a car on EBay again without viewing it first!
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Oct 2012
    Scotland
    237
    Got the downpipe off this morning
    Does anyone know the diameter of the standard exhaust, think I'm going to need a reducer pipe as the downpipe is 2.5"?
    Oct 2012
    Scotland
    237
    Found the info using the search function
    2.25" apparently....off to find a reducer
    Jun 2012
    i shall be removing a downpipe on an agu soon, how did you get them undone in the end? hopefully no broken studs?
    cheers, rob.
    Oct 2012
    Scotland
    237
    I'd soaked everything with PlusGas the day before and my flexi had broken away so access to the bolts on the turbo was good. With the car on the ramps on the driveway it was awkward but ok. Hardest bit was getting the sleeve off the exhaust section which still isn't quite done.
    No broken or snapped studs though!
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Jun 2012
    excellent, did you need heat or did they undo cold with just the oil soaked on them?
    Oct 2012
    Scotland
    237
    Mine didn't but a few people have suggested this...I think it could have been the liberal soaking with PlusGas or I might just have been lucky.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    hello matey, just read your PM.
    Stock exhaust is indeed 2.25'', 57mm.
    The decat should reduce to 57m also and the stock exhaust slide over it though.
    What size is the end of your decat?
    Oct 2012
    Scotland
    237
    It's a 2.5" Toyosports/EBay job, I'll need to double check the size of the pipe where it meets the existing exhaust, I've maybe just assumed it's 2.5" all the way. You reckon it tapers to 2.25"?
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    I'd check it all out first mate. Most decats reduce from 3-2.5-2.25 to mate to the stock system.
    Oct 2012
    Scotland
    237
    This one is 2.5" all the way, will get a reducer pipe made up and finish fitting this week
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    WorkInProgress: how did you get on with the DP? I assume you've fitted it and had a reducer made? Do you have a link to the DP you bought? I'm currently pricing them up - what's your thoughts on this eBay special SEAT LEON AUDI A3 1.8T 20v STAINLESS STEEL 200 CPI SPORTS EXHAUST DOWNPIE | eBay ? Is it similar/the same as the one you've fitted?
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Oct 2012
    Scotland
    237
    Quote Originally Posted by JudderMan View Post
    Sorry for the delay in replying! That looks similar to mine, except mine has no cat. Good fit, relatively easy to do. I got a 2.5" one but I think the general consensus would be to go for a 3" for future proofing if you were to go for a K03s at some point
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Quote Originally Posted by WorkInProgress View Post
    Ahhh, I have an AUM with a K03S anyway, so you'd recommend 3" then for my application? I'm only going stage 2 and no more* btw.
    *famous last words.
    Oct 2012
    Scotland
    237
    *famous last words.
    I'm not 100% sure, best asking on here first before making a purchase! I think 3" would be best but I'm sure someone on here could confirm this for you
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    3'' downpipe for ko3S please lads
    WorkInProgress likes this.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Prawn to the rescue once again Thanks pal.
    Right then, Relentless V3 seems to be the order of the day I do believe - I'll check prices as I'm not sure what they go for. I've had quotes for a Milltek £369 for a cat back or £300 from Powerflow but I want a resonator which the Powerful doesn't have so it might bump the price up. After that, it's mapping time
    ecudude's Avatar
    Dec 2012
    17
    Hope its ok to restart this tread. I am currenly looking at a smilar item on eBay for my A3 1.8T 1999 AGU:
    SEAT LEON 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    The seller said it will not fit my AGU only AUM and AUQ coded engines (I guess these engine are from the facelift from 2000-).
    After searching the web, I cant find any post on this subject, that there is in fact a difference....
    Are the seller correct on claming it will not fit AGU engines?
    Please advise, since my original down pipe cat assy is struggeling with leaks and old age ;-)
    Oct 2012
    Scotland
    237
    This should fit fine so long as yours is a FWD i.e. not a Quattro
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    ecudude's Avatar
    Dec 2012
    17
    Yes mine is a FWD. After more searching the net, it seems that all FWD golf MK4's and A3 8L, have the same front pipe with cat.
    The eBay front end pipe have different titles/description but seems to have the same picture for all:
    Skoda:
    SKODA OCTAVIA 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    Golf/Bora:
    VW GOLF BORA 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    Seat Leon:
    SEAT LEON 1.8T 20v STAINLESS STEEL 200 CPI SPORTS DE CAT EXHAUST DOWNPIE | eBay
    any objections ;-) or those this seem resonable.... that they all will fit.
    Audi A3 1.8T AGU 1999, FWD, 5D, Attraction line, K03, 205000 km. Mod's: should be chipped; 195bph or so... Silicone TIP, Sport CAT 200 Cel.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    AGU/AUM downpipes are all the same, AGU only uses one lamda hole, but they come with plugs anyway.
    It'll fit yours fine mate.
    ecudude's Avatar
    Dec 2012
    17
    Yeah, the second lamda should be easely plugged (maybe that's way the seller states AUM and AUQ only???!!)
    Thanks for the swift replay, workinprogress and prawn.
    I will but in some bids, and replay with some pic of the goodies, when it arrives :-)
  28. #27
    ecudude's Avatar
    Dec 2012
    17
    PS would it get much louder with this down pipe cat, on an original existing cat back system(trough a downpipe of course :-)
    Could the material stainless steel be rather thin.... making "thin can" sound from the system after fit?
    Anyone now the difference between say a miltek or jetex downpipe cat, in compare(except prise)?
    Just curious
  29. #28
    ecudude's Avatar
    Dec 2012
    17
    Well thats a blow out... my bidding item was removed in the hours of the last day:
    This listing was ended by the seller because there was an error in the listing.
    my bid was @41pound....
    well back to square1..
  30. #29
    ecudude's Avatar
    Dec 2012
    17
    Smile ebay downpipe CAT arrived!!!
    I finally got a bid at 124£. I promised som pic's, here you go:
    compared with the stock;
    Installed:
    But I got an major issue. There is not enough clearance to the crossmember, so there is a banking sound at startup and when giving some throttle:
    What to do?
  31. #30
    ecudude's Avatar
    Dec 2012
    17
    I will check my engine mounts this weekend, to check for excessive play and worn rubber iaw this tread:
    Engine mounts replaced (with pics)
    My gearbox LH mount do seem a little swaggy... Not sure if the dogbone has any part inn the height off the engine in the bay, but I will check it out as well.
    By the way, should I remove the heat shield on the crossmember,or is that not recommended?
  32. #31
    ecudude's Avatar
    Dec 2012
    17
  33. #32
    ecudude's Avatar
    Dec 2012
    17
    You can see here that the original down pipe have a "bend or turn" around the crossmember:
    Just checked the LH transmission mount, and it have only a slight tilt to left(to the rear of the car):
    Seems rather tight, with normal wear and tear....
    I wonder if it will help to install the Vibra tech engine mounts "Road" version:
    Left Hand Engine Mount Mt 18 V6 - Vibra-Technics Compliance Technology
    Or is this waiste of mony for daily road drive only, and possibly more noice in the compartment?
  34. #33
    ecudude's Avatar
    Dec 2012
    17
    Found this kit of spacers to raise the engine:
    Mk4 Motor Mount Spacer Kit | Euro Image Tuning
    This I think would make enough clearance for my down pipe. They are currently sold out on 5∕8", so maybe go for 1"?
    I put LH engine mount in a wise, and managed to tilt i over, to a more level position. Further I have treated my LH mount with a sealant, and now waiting for it to try out. There was a lot of space to fill up with sealant
  1. Downpipe fitting
    By s3 ryan in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2009, 12:36
  2. Silicone TIP for my AGU K03s (Fitting)
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 11:04
  3. Quick video with new downpipes fitted
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2009, 22:30
  4. S4 Downpipe fitting, how hard is it?
    By OllyS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2009, 08:29
  5. Downpipe Fitting
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2007, 14:44
