Sky InsuranceVolks Autos
Results 1 to 8 of 8
Thread: no start!!!
    Nov 2012
    no start!!!
    i need to fix an a3 '99 its done about 98,000 & has not yet done its annual service but has had a clutch change, days after i had noticed that a wire was coming out of the sensor that leads to the coil (no 1 of 4), that has now been amended. Now the car wont start it was having trouble starting before but there was spark coming out of plugs so i managed to get it to start but now there is no spark i have changed the plugs & the coil but yet no luck, it does crank doh but after abit the oil light comes on, i haven't plugged it into a diagnostic reader yet, im running out of ideas i would like it fixed as soon as, so if any could help me i would b very great full.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Knackered coil pack wiring?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Crank sensor maybe... scan for fault codes first...
    <tuffty/>
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    You really need some fault codes first, as they go a long way and can save you huge amouts of time and money
    Lewis583's Avatar
    Mar 2010
    870
    As said sounds like Crankshaft Position sensor issue, but a diag scan is the best place to start. When it is plugged into a diag machine, call up the actual values/measuring blocks and watch engine speed when turning over. Should give a reading <500rpm-ish when cranking
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Nov 2012
    thanx 4 the response guys!!!
    rite ive pluged her in & its worse then i fout, theres 6 engine faults & 4 others that i found when i went in2 the other menus...
    Attachment 8457Attachment 8458Attachment 8459Attachment 8460Attachment 8461Attachment 8462...Attachment 8463Attachment 8464Attachment 8465Attachment 8466
    so wer shall i start?
    lewis i havent looked but i fink my device dnt have the option to check actual values/measuring blocks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    clear them all off
    then try to start and rescan
    but im gona go with the G40 sensor is your problem
    Nov 2012
    that was the 1st fing i did bro, i fout it wud b that g40 also coz thats what people was saying but the only code that was left was the speed sensor code IMG00325-20121117-1243.jpg
    so is it that or?
  1. starting cut off
    By sahkel in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2003, 15:35
  2. NOT STARTING ON THE BUTTON AND BRAKE JUDDER
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2003, 10:45
  3. A squeeky start.....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2003, 23:34
  4. The war has started...
    By amoffat in forum General Chat
    Last Post: 24th March 2003, 12:24
  5. Won't start!!
    By ray_nsm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2003, 00:25
