EM TuningVolks Autos
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By phil miller
  • 1 Post By Lazaros
Thread: Dashboard replacement
    Mar 2012
    17
    Hello guys...
    I have a simple question.On my '99 A3 1.8T I have an almost destroyed dashboard screen(many dead pixels).
    I have found a used dashboard for not so much money.I know how to dismount the old one and install the "new" one.
    Is there something else i should do than just connect it?Could be any problem about milleage,immobilizer etc. ?
    Thanks in advance
    phil miller's Avatar
    Sep 2012
    Devon
    843
    The cluster will need to have your immo program added, the new one will fit, light up but you engine won't start unless you have it programmed I know someone on here can do it but for the life of me can't remember who think its Danny, sorry I can't help more dude
    Mar 2012
    17
    Then the process will be little longer.I live in Sweden,but thanks anyway Phil.
    Is it possible to just replace the screen on the damaged dash ?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,641
    You can have it repaired, if you do a search, there was quite an extensive thread on repairing a dead display with pixel issues.
    Mar 2012
    17
    Yes i know...I have tried to repair mine by warming the tape cable,but nothing happened.Then i warmed it little more,so the tape has been damaged a little bit.The question is how easy is to attach a new screen with its tape cable on the existing board.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    718
    You can buy a DIS replacement screen off ebay for about £30 if I recall correctly, looks a tricky job to unsolder and then resolder the new one in place and I'm not that brave yet to do mine. If yours is already damaged then you probably have nothing to lose by giving it ago.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Mar 2012
    17
    That's what i'm thinking about...It can't be worst.But i have already ordered a genuine used cluster and i wonder,what could be more tricky?To switch the screens from the "good" one to the damaged one or just to mount the new one and reprogram it?
    Sep 2012
    Devon
    843
    I did read somewhere they use low melting solder as normal solder temps can damage the processors, id give it a go but im not that brave just yet lol
    sportquattro likes this.
    Mar 2012
    17
    It's always good to try,but a mistake in that case can cost another cluster...How much can somebody take to reprogram a new cluster?
    Sep 2012
    Devon
    843
    Danio on here can do them, iirc when i asked him he said he would need the new (to you) cluster and your spare key, he will then program the cluster so you just plug it in and it works, think it was about £50 but i may be wrong, i knew id spoke to someone about it
    Mar 2012
    17
    Ah ok...Sounds good price and kind of easy job for a specialist.I'm living in Sweden,but it's good to know about the prices around,so i can look for somebody here.Thanks a lot mate
  1. dashboard lights
    By A4Steve in forum Classic Audi Forum
    Last Post: 13th December 2007, 10:03
  2. FPR replacement
    By tbird_gprs in forum Tuning
    Last Post: 8th August 2003, 11:17
  3. MOVED: Replacing wifeys VR6
    By gtdog in forum General Chat
    Last Post: 4th July 2003, 18:49
  4. All dashboard lights out on A4?????
    By MarkR in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2003, 13:11
  5. want to replace head lights on a4 1.8t sports
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 22:15
