Volks AutosEM Tuning
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By dancupra225
  • 1 Post By camscockle20vT
Thread: 2001 Audi A3 1.8T Hissing Sound.
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Hi all this is my first post and it's not a good one unfortunately.
    I was driving my A3 happily on my way to pick up some shopping and my engine light came on so pulled over and switched it off, i then started it again and the light was still on, it has ruff idle and a really loud hissing noise coming from under the fuel rail.
    The temp on the dash is fine but under the hood feel's very hot and the plastic engine cover was to hot to hold in hand and the fans kick in almost straight away.
    Any help would be great.
    Kind Regards,
    Neil.
    Apr 2012
    490
    hose is off or massive hole in it check your hoses when you hit boost does it feel flat
    Neil-M likes this.
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hi mate its most likely your pcv pipes under the inlet manifold, main dealer part or do the n249 valve delete which costs about £5 to do, thread is in the stickies.
    Hope this helps.
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Thanks for the replies, i found a split hose, it's a short almost "L" Shaped hose the is different diameters at either end that comes from the inlet manifold to another connecting hose. Does anyone know what the hose is or better yet the part number as there was nothing on the original. would this split cause the engine light to come on also and for it to run so hot?
    Many thanks.
    Nov 2010
    1,673
    Yes mate its the pipe that i mentioned thats under the inlet manifold, maindealer or tps.
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Hi thanks for that, do you know the part number for a replacement at all?
    VAB
    VAB's Avatar
    May 2012
    Australia
    44
    First post in this thread has the part Nos of the hoses under the manifold
    Guide - How to fit a catch can and simplify the PCV system
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Brilliant thanks for that it looks like the part i need is 06A-133-783-AS, Are these a common point to split at?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Very common mate...As said i would consider doing the catch can mod.... well worthwhile
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    cheers mate i still need to order that part to do the mod?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    No mate it gets deleted...
    Neil-M's Avatar
    remedy
    Nov 2012
    Torquay
    26
    Oh right thats great. Could i alsoask what themp temp gauge should be running at once warmed up?
    VAB
    VAB's Avatar
    May 2012
    Australia
    44
    Temp gauge should sit on 90 if not it is the stat or temp coolant sensor.
    AS per Dave look at the catch can delete that I posted as if it is like mine all the hose are the same age and once you start replacing one the rest are not far behind.
  1. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2005, 18:24
  2. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2005, 09:35
  3. CHROMED-out 2001 AUDI S8 - CRAZZZZZZY!!!!
    By josejay in forum A8/S8 forum
    Last Post: 6th February 2005, 16:34
  4. Ekta cd for 2001> Audi A4 (B6)
    By firestorm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2004, 13:02
  5. CHROMED-out 2001 AUDI S8 - CRAZZZZZZY!!!!
    Last Post: 19th November 2003, 04:58
