JMB RetrofitsAH Fabrications
    Oct 2012
    23
    s3 gearbox removal
    just to confirm, the audi s3 gearbox can be taken off without takin transfer box off wich i had to find out the hard way lol, was told by around 6 people who work in garages that the prop and tb hat to be taken off inorder to remove the gear box???
    VWVortex.com - Transmission Removal Clutch Replacement diy Quick Version
    phil miller's Avatar
    Sep 2012
    Devon
    843
    you have to undo the 3 bolts on the prop, remove the driveshaft on the o/s, using a long 6mm iirc allen key undo the bolt in the centre of the T/box drive flange slide off the transfer box then remove the gearbox as if it was a FWD car, its not that bad to do mate
  1. Quattro gearbox removal on A3 3.2 V6 (2005)
    By bn9af in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2011, 18:46
  2. Gearbox removal
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2009, 18:40
  3. A3 8L Quattro gearbox removal please HELP
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 18:27
  4. A3 Quattro Gearbox Removal
    By A3Quattro1985 in forum General Technical / How To
    Last Post: 24th January 2009, 00:00
  5. a3 quattro gearbox removal??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 20:52
