Chris NottAH Fabrications
Results 1 to 8 of 8
    Feb 2012
    135
    tech info needed please fault code inside.
    hello people, right my problem is im getting the engine management light coming up with the fault codes p1557 and i have no idea what it is! lol sorry but like i have explaind before im new to cars so im often in need off advice! my brother normally does all this for me but hes away at the mo so im sh1t out off luck! any info would be helpful! oh and the engine code is ayp dare i say it....a bloody cupra! Dont hate me the s3 is now about to come off the road for rods and pistons so the cupra is my loan car! lol.
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    17965/P1557/005463 - Ross-Tech Wiki
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    Sounds like its over boosting to me...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    *edit*
    Dammit Tuffty you're a ninja!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    You knowz it!
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,156
    guess who works in IT = very busy working............
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Feb 2012
    135
    Thanks for the above. Right I plumbed in a boost gauge to see what it's producing and it's only hitting 4psi! Unplugged the n75 and still no change so changed it for a spare and it's still crap. if I pull the pipe off the actuator it hits 15psi every single time it comes on boost? What am I missing as I have no idea what's going on? HELP!!!!!! Fooking cupra!! Sorry bill I know you race one! Lol cheers fellas
    RIP S3dave
    May 2004
    nr Glos
    7,156
    its in limp mode = actuator pressure.. N75 electrically disconnected = actuator only pressure
    clearing fault codes should bring it back to life until it exceeds its boost request again by 250mb and limps again
    if 15psi is all it does with nothing connected to actuator its sounding quite tired... it would do way more than that uncontrolled
    bill@badger5.co.uk
    Feb 2012
    135
    Done that bill but comes straight back on limp! Any ideas?
    Would your money be on a dead actuator then? Have a spare k03 kicking about so would you say change the actuator and see what happens from there? Cheers
  1. Help needed with fault codes
    By j4jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2008, 06:59
  2. need help fault code
    By audi-90qua in forum Classic Audi Forum
    Last Post: 28th October 2007, 12:22
  3. Alloy wheels....info needed! please help
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2007, 12:51
  4. What are your front wipers like? Info needed please!
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2006, 11:01
  5. A3 Sport info needed please
    By bendz in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2005, 10:37
