JMB RetrofitsBadger5
    Nov 2011
    devon
    87
    Smile air con returns to 23 degrees all the time?
    hi all,
    as above really the air con on my 2000 s3 always returns to 23 degrees when i start the car. will it not stay on the temperature i left it at?
    I havnt had the car long and my old a3 didnt have aircon,
    cheers kryton
    Oct 2012
    Telford
    95
    Im not sure how tor resolve it but I think it should yes as mine stays at what it was left on
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Are you using the same key? The climate stays on a desired temp due to the key aswel! If you go to HI and then switch the fan off, it'll go to a certain temp - that's what mine does
    Nov 2011
    devon
    87
    ok thanks will try that , been using same key
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,090
    Mine always stays on whatever I left it at when switching the car off. I do always switch it off before switching the car off though, so not sure if that makes any difference at all or not.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    The settings are stored per key.
    So if i get in, set it to 21c and ECON, then the missus gets in and sets it to 18c with AC and full blowers, when i get in again with my key, it returns to 21c and ECON.
    Perhaps theres a comms or coding issue between the climate unit and clocks, so the climate unit doesnt know what keys being used?
    TD5 Land Rover Defender build
  1. hot air all the time even when on cold !
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th April 2011, 13:57
  2. AIR -CON BLOWING OUT HOT AIR ALL THE TIME!!!!....
    By jondonna8276 in forum Air Conditioning
    Last Post: 31st August 2010, 21:50
  3. second fan on full wack all the time
    By auroan in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th December 2007, 22:47
  4. Pre-facelift door mirrors-heated all the time?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th August 2006, 12:27
  5. Things that go bump.... all the time !!!!
    By Geronim0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2005, 15:53
