Chris NottMonster Motorsport
Results 1 to 9 of 9
    Nov 2004
    21
    Boost question to chipped s3\'s
    To chipped s3 owners, I assume you have around 250 bhp, What boost do you have, constant and peak ?
    Feb 2004
    Leeds, Leeds, Leeds
    69
    Re: Boost question to chipped s3\'s
    mine peaks at 1.6bar
    Nov 2004
    21
    I get 1.4bar when I hit the gas pedal strongly at the first time , but it than sits to 1.1 bar and it stays there until 6000rpm. What constant boosts do you have ?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,424
    Peaks at around 1.4/5bar during the midrange, then settles to 1-1.1bar at top end on my car.
    imported_plexxi
    I have a MTM chip and mine also peaks at 1,5 when you hit the accelerator and then settles at 1,4 bars during the midrange revs.
    Feb 2004
    UK
    1,320
    When it was chipped it was 1.1 peak 1 held.
    Feb 2004
    Leeds, Leeds, Leeds
    69
    mine settles around 1.1
    ELIASGK74's Avatar
    Mar 2004
    greece
    47
    1,75 overboost from low revs,
    1,2 until 6200
    1,1 later
    with ttda,full exhaust 70mm with one free cat,free afm,samco tip
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    A bit more than a simple re-map...but mine was running:
    1.85-1.89 peak.
    Holding 1.3 to 6800RPM.
    Torque at 330lb-ft and power at 275 ish.
