Sky InsuranceBadger5
Thread: Subframe bushes
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Subframe bushes
    Hi, I need to change my bushes in the subframe as they are pretty cracked on the drivers side, is there any better ones than the standard ones I have seen on eBay? Ill be looking to have this done pretty soon as we'll as getting an s3 arb so I'd do the two at the same time.
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    By subframe bushes do you mean the front suspension arm bushes?
    Normally use TT spec solid bushes for the rear bush and a powerflex for the front bush
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    No not them but that was going to be the other one I was going to ask about the tt ones, the ones I am meaning are when the car is on the axle stands there are what looks like 4 bolts that that connects the subframe to the car? Well the one on what I can remember of top of my head is at the back of subframe and its a rubber bush and mine is split
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    You talking about the billet subframe bushes that replace the actual subframe bushes at the rear?
    Jun 2012
    Redhill Surrey
    635
    Yeah I think so, they have a bolt that goes through it and its has rubber round it that has split, so I would think we're on about the same thing
  1. S3 subframe bushes.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2012, 21:34
  2. Replacing bushes - new subframe / suspension bolts?
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2012, 22:28
  3. front poly subframe bush??
    By ANDYMC_TQS in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2012, 17:36
  4. Replies: 4
    Last Post: 9th August 2010, 08:25
  5. Subframe bushes A4
    By AndyC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2007, 10:59
