    Sep 2012
    Colchester
    90
    Coolant Temp Sensor
    If this is knackered can it cause white smoke from exhaust? I thought my head gasket had gone but ive got no mayo on oil cap, nothing on dip-stick and the coolant is oil free. I have noticed alot of wet around the CTS though so im gonna replace it. Is it worth going to audi or is there a better aftermarket option? Also it is using a small amount of coolant - but nothing major over the last 290 miles.
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    Rota Grid Drift 9.5J alloys
    AP coilovers
    PCV oil catch can (to atmosphere)
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    yeah just get a new CTS and o ring from the stealers fit it (when engine is cold so you done lose any more coolant) and then clear any codes in the ECU.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Oct 2012
    Leicester (LESTA)
    57
    Have a look on the thread I've started as these are usually the symptoms.
    Sep 2012
    Colchester
    90
    Update:
    Right, after driving back home from visiting friends and family in manchester i fitted new CTS.
    Since i noticed the white smoke, ive done almost 600 miles and had none of the other usual signs to show a kaput head gasket (water/oil mayo mix). Ive changed the CTS, still have some white smoke.
    So, got the missus to give the car some revs while i checked the expansion tank - bubbles after revs have dropped. Which would suggest combustion fumes are getting into the coolant... just surprised ive not got oil visable.
    So, next i double check by having a garage do a sniff test. If its 100% gone ill whip the head off and have it tested and fit a new gasket if all is well.
    .... Sounds so easy when its typed. Not looking forward to actually doing the job!
    Almost tempted to buy relentless DP & cat and do that at the same time
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    AP coilovers
    Sep 2012
    Colchester
    90
    Update - Figured id post an update on this incase anyone in future has similar issues and searches the forum.
    Right.... The white smoke stopped, but that was because the PCV system decided to split.
    Turns out, the PCV pipes were just completely full of gunk and that was getting into the engine - causing white smoke out the exhaust.
    Its actually more snapped in half than split. Ive bodged repaired it so at the moment the car is running like ive filled it with sand. So will be sorting this tomorrow.
    As for the coolant loss - turns out a braided hose near the turbo is leaking coolant (judging by the amount of coolant all over it) so will replace and hope this solves the coolant loss issue.
    SO, to recap. PCV filled with gunk caused white smoke to chug out the exhaust. White smoke issue fixed, running like a bag of spanners will be sorted tomorrow with a new pipe!
    ah the joys of cars!
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    AP coilovers
  1. Help! Where's the Coolant Temp sensor?
    By FactionOne in forum General Chat
    Last Post: 12th April 2006, 09:44
  2. Coolant temp Sensor
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2006, 12:38
  3. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  4. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  5. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
