EM TuningMonster Motorsport
    Jul 2011
    peterborough
    32
    boost gauge fitting
    Hi i was just wondering which is the best pipe to use to connect the boost gauge feed pipe too? I a bit unsure if it be better nearer the engine or along any part of the boost pipe
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    AFAIK, It needs to come off the intake manifold. Some people T off the fuel pressure regulator (FPR) vacuum line, others T off the diverter valve (DV) vacuum line. The best way would be to fit a new fitting into the manifold but that's more involved.
    There is a lot of boost gauge how to's on here.
  1. APR Boost Gauge Fitted!
    By mattfinn in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2008, 17:16
  2. Boost gauge fitted
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2008, 18:35
  3. boost gauge fitting
    By Ricco in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2006, 17:02
  4. boost gauge fitting
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2006, 18:57
  5. APR Boost Gauge Fitted
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2004, 08:22
