Badger5EM Tuning
Results 1 to 8 of 8
    imported_Wicked666
    Quick Tyre pressure question
    Do I have to run same pressure in all 4 tyres if I have a quattro?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,598
    Re: Quick Tyre pressure question
    [ QUOTE ]
    [/ QUOTE ]
    Not really, try 34 fronts and 36 rear for better front end bite if you have 18s [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    scoTTy's Avatar
    Essex, UK
    1,958
    On my TT is was 36F 30R
    My S4 is 39F 39R
    Quattro isn't the thing that determines your pressures
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    and if i am running 17's - dont want to go for 18s as i haven't heard great things
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Try the fronts at the pressures for 2 people, and the rears at the pressures for four people...all available from the info sticker.
    BTW, there are no negative effects of going to 18s...but the 19s no have negative affects....IMO anyway.
    scoTTy's Avatar
    Essex, UK
    1,958
    ...apart from a harder ride, possible increase in unsprung weight and therefore worse handling, more risk of bending your wheel due to less sidewall, more expensive tyres, etc.... IMO [img]/ubbthreads/images/graemlins/grin.gif[/img]
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    yes weight, i may just drill mine out!! thanks for that, as long as i can get some brembos in the 17's I'll stay. That reminds me I have some question for a new post
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Not so...play with the tyre pressures!
    mine rides better on 18s and handles better, turns in better, is less fidgety etc...
    [ QUOTE ]
    [/ QUOTE ]
    Yeah, if you fit cheap-ass replicas. Stick with properly engineered lightweight wheels and decent tyres and you'll save weight.
    [ QUOTE ]
    [/ QUOTE ]
    Sossibly so...again, light, strong wheels will reduce this risk. You'll still bend a 17@ if you drive like an idiot on bad roads!
    [ QUOTE ]
    [/ QUOTE ]
    OK...you got me.
    It'll cost you about a tenner more per tyre! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
