JMB RetrofitsEM Tuning
    Sep 2012
    West midlands
    368
    Vacume brake booster?
    Hi can anyone tell me how the brake booster under inlet manifold operates shoul it blow air through both ways ect? Can this cause boost issues?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    There is no 'brake booster' under the inlet... can you provide a little more info, your description is a tad vague... model/year of the car?
    If referring to the brake servo vacuum hose... on an S3 the check valve is fairly close to the servo... on an A3 the check valve is in the pipework as it routes towards the bulkhead gearbox side of the engine...
    <tuffty/>
    Sep 2012
    West midlands
    368
    It's an Audi s3 8l 2003 inlet manifold were dipstick goes directly underneath 90 degree elbow then a black vacume booster apparently Audi say!! Has 3 outlets one is too pcv valve??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Its called a vacuum pump and not really anything to do with the brakes...
    Most people remove all of this to simplify the PCV and vacuum system... less pipes to spilt and cause probs, PCV delete so no oil going into the inlet to dilute the fuel... win win...
    <tuffty/>
    Sep 2012
    West midlands
    368
    I've just bought new pcv and forge hoses but when changing oil was in pump and pipe work so??? And I was able too blow through ?
    Sep 2012
    West midlands
    368
    Do you have link too simplify pcv ?
  1. TDI 170 Brake booster & associated vacuum lines
    By max69vk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2012, 21:10
  2. More problems.. Brake booster pipe from inlet to master cylinder and maf
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2012, 10:00
  3. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  4. S3 Brake Upgrades - not Porsche/Brembo
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 17:05
  5. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
