Chris NottJMB Retrofits
    Jun 2004
    Surrey, UK.
    269
    Does this exhaust pipe need trimming ?
    Some of you may have read the trials and tribulations of my adventures of fitting a new DP.
    I now got to the bit of conencting the sports cat to the rest of the (original) backbox.
    There is approx 13mm overlap of the two pipes. There is enough flexibility in the exhaust system for me to butt them up, bu it does mean the thing is under pressure.
    Is this ok, or should I trim the length say by 40mm so the pipes, especially the downpipe end is not under constant pressure ?
    fs
    The white stuff is firegum
    Oct 2011
    760
    i cut mine, and fitted the sleeve over the top packed with gum gum.
    will get back to you in the morning, have seen an inline catch can online but cant find it.
  1. What does this loose pipe do?
    By Vex182 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2012, 20:23
  2. What does this pipe do!? Part number please
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2010, 10:49
  3. Why does this 5000 quit on its own??
    By Sabre60 in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:40
