Chris NottVolks Autos
Results 1 to 7 of 7
    ZAS
    Jun 2012
    64
    Oh bugger, gearshift cables...
    Hi,
    Just installed new shifter bracket bushes on my car, and re-installed the shifter bits and now the gears aren't slotting in so nicely, and I can't get reverse.
    Is there a specific position the shifter needs to be in before I re-attach the shift cables?
    Cheers,
    JB
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What sifter(s) have you fitted? What settings are they on? Have you done the gearbox resest?
    ZAS
    Jun 2012
    64
    Hi Dani,
    Just re-installed the standard shifter. Do I need to do the reset even if I haven't installed a short-shifter?
    Jason
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    yup, needs resetting mate.
    Pull the gaitor off and you'll see a small hole in the stick, which lines up with a hole in the base. drop a 4mm allen key down there to fix the stick in one place.
    On the box, there's a little lever sticking out, wiggle the shift weights around until you get this lever to move in and turn 90 degrees to lock it, then pull back the spring clips and let the cable ends sit as they want to. release the sprung part, pull the pin out at the box and pull the allen key out at the stick and it should all be lined up
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Are they the ones from 034 motorsport of something, their billet or steel instead of the rubber standard ones?
    As prawn has said you need to reset the gearbox no matter what.
    Oct 2011
    760
    ZAS
    Jun 2012
    64
    Shot guys, will do the reset, thought I only had to do it after dropping a short-shifter in...
    JB
  1. Bugger, another speeding ticket
    By Gambba in forum General Chat
    Last Post: 30th October 2003, 14:01
  2. Power cable
    By L14MDP in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2003, 18:16
  3. Help Installing Kenwood music Keg cable
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 07:35
  4. Replies: 5
    Last Post: 31st July 2003, 08:46
  5. Need help fitting a CD changer cable
    By Kevint in forum In-Car Entertainment
    Last Post: 16th July 2003, 10:50
