Volks AutosSky Insurance
Results 1 to 21 of 21
    Sep 2012
    40
    Thumbs down Brake Light Switch - 0526 Haldex not working. Audi S3 8L.
    Hey everyone. This is my first thread I'm from Venezuela.
    I'm having this problem with my Audi S3 8L BAM 225. I have the "brake pads worn" yellow light on in the DIS. But I just changed the brake pads like 3 months ago, with it's proper wiring and everything. I connected the Vagcom and it says Brake light switch F implausible signal 0526 but my brake lights do work properly. It only shows when I log on 22-AWD, not in the complete scan. My car feels like fwd, no rear traction. I bought it in december 2012 with 68km on the clock. I don't know if the previous owner changed the haldex oil and filter. What could it be? Thank you in advance.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    823
    Add Vex182 on Facebook
    It's the actual brake light switch on the pedal that's gone, it's fairy common. Fit a new one and clear the codes and all should be good. The haldex won't work because its getting a siginal telling it that your braking.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Sep 2012
    40
    Thank you very much for the reply. Will try that and post later! Cheers
    Sep 2012
    40
    A little update here. So I bought the Brake Light Switch and replaced it, deleted the codes and now working fine but still got the "Brake Pads Worn" Yellow light on the dis and still no haldex .
    Maybe the pad's sensors causing this? Or the "Brake Pads Worn" yellow light won't make any difference with the haldex?
    Sep 2012
    40
    I just took off my wheel to see the brake pads sensor wire and its gone, it's totally disconnected from the pads. Could that be the cause? What can I do to fix this without buying a new set of brake pads?
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    The eaisest way is to link the two cables from the cars sensors together. This will sort that warning out.
    Sep 2012
    40
    Yeah I read that in other threds but my question is if that will sort out the haldex problem? Will do that anyway and see.
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    When my brake pads were worn and the warning came on, I did not notice any issues with the haldex to be honest. What year is your car?
    Sep 2012
    40
    It's a BAM 2003.
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    Sorry I have just seen its a BAM engine, have you checked your earth strap for the haldex?
    Sep 2012
    40
    That will be the next thing I'll do. That's the strap located next to the haldex unit right? In the driver's side.
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    Yeh it's about 10" long. Can't remember which side off the top of my head.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Quote Originally Posted by ceS3r View Post
    its visable from the passenger side as i replaced mine last week and now have communication with my haldex via VCDS. Once i had established connection i found a brake light switch fault which must of been stuck in the haldex for ages so now thats cleared and has not come back.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Sep 2012
    40
    Thanks for your replies
    I lifted my car up today and check for the Earth Strap and it was there, very tight. So what's next? Could be the haldex controller? Or the pump? What are the symptoms? Or maybe, an oil and filter change could help?
    Sep 2012
    40
    Little update here. So I had my car on a lift today and checked everything underneath. Earth strap is ok, I pulled it a little to see if it was well attached and it was perfectly attached. Checked the pins to see if they were corroded and they were in perfect state. I run my vcds for codes in the AWD again and again, no fault errors. I run vcds on my abs and also no errors. So, what could it be? Is there any way to test the haldex pump? Or may be the control unit? I just don't wanna buy one of them if they are not the problem, they are very expensive. Any help would be appreciated.
    Apr 2012
    491
    Re: Brake Light Switch - 0526 Haldex not working. Audi S3 8L.
    How much did the brake light switch cost and how hard to fit ? As mine has gone. As well.
    Sep 2012
    40
    It's not that difficult. You need a torx screw driver to remove the panel that's above the pedals. After you remove the panel, you will se the brake light switch located over the brake pedal, it's a black piece. Twist it counter clockwise to unlock it and take it out. Press the brake pedal back and with your other hand fit the new one, let the pedal go back to it's normal position while still holding the brake light switch so it wont come back, and after that, rotate the new brake light switch clockwise to lock it. And that's it. It is a one time shot so do it carefully. Mine was 400 bolivares (venezuelan currency)thats like 35$ aprox.
    Sep 2012
    40
    When I try to log with my vag com (VCDS lite free version), on 22-AWD, at first it shows no codes, but when I click, clear codes, it says "Retrieving fault codes" After that, appears a message that says "No fault codes found, or dtc not supported by controller or communication error" ?
    What does this means? I am thinking in buying the blue controller but just want to be sure that's the fault.
    Apr 2012
    491
    Well I've done mine and now have clutch fault so going to service it check earth strap and wires to haldex
    And hope
    Diffs go for 200 quid on eBay at more so not to bad
    Sep 2012
    40
    That's the problem, I checked the earth strap and connectors to haldex and they were in perfect state.
    Sep 2012
    40
    Just trying to remember when my haldex stopped working. I had a personal mechanic who took the car to do some fluid changes, like oil and coolant change. He got the car on a lift, and told me that they were some electrical stuff problem and he sorted out. Like 2 months later, I was on a traffic jam and my A/C wasn't working, and suddenly the water temperature started to go up to 120. I was near a parking lot so I entered there and turned off the car. Almost all the coolant was gone. It turned out to be the battery fuse that was blown and the fans weren't working. I remember that day was the day my haldex stopped working. Just to be sure, the two fuses that are next to the fans are for the abs, correct me if I'm wrong but one is for the ABS and the other for the ABS pump. I also have heard that if something wrong with the abs, haldex won't work. Those two fuses are in very good condition. So, my point here is, maybe the mechanic did something wrong with the electrical stuff and it cause the fuse to blow, and maybe there is other electrical problems with the abs causing the haldex won't work? I don't have abs light on the dash.
    Just hoping to someone can help me, thanks.
  1. Audi A6 98 Q number plate light and rear fog not working
    By MADEIRA in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th April 2012, 20:13
  2. Cruise control not working - brake light switch to blame?
    By skyegtb in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd October 2011, 14:49
  3. Replies: 0
    Last Post: 6th June 2011, 17:11
  4. Replies: 5
    Last Post: 20th May 2009, 14:23
  5. Reverse Lights not working Audi A3 1.8 T
    By andybubbles in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2005, 10:37
Tags for this Thread
