Results 1 to 11 of 11
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Changing rear arms and arb
    I'm going to attempt to fit 4 adjustable rear arms tomorrow and the ARB. Anything I should look out for? ARB appears to be an exhaust and heat shield off job, then pretty straight forward. Arms a like for like replacement, one at a time?
    I'm going to match the length of the arms to the OEM ones and maybe adjust some of the camber out a touch before I get a proper alignment done.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    You just need to drop the exhaust from the body, no need to remove, just undo the hanger plates and it will drop...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Ideally, you need a big box or a trolley jack of some sort to support the exhaust backbox, or all the weight will be on the center exhaust hanger. Consider I've not done it before, I manage to do it on my own on axle stands outside my house, it's not a difficult job.
    The lower arms are straight forward also, just make not of where the xenon height adjuster arm bolts to and mark in the same place on the replacement arms, the top ones are a bit more trickier, you need to undo the rear subframe bolts to get them off, s3dave has done a how to guide elsewhere on the forum to swop those over.
    You've got to have a laugh!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Ah, sounds like a job for another day then if I have to remove the subframe bolts. I have the headlight adjuster adapter from Gruvenparts so should be ok there. I read that you need to fit new bolts too? Is that right?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Quote Originally Posted by Sam_ View Post
    It's just two bolts from the subframe to allow clearance for the bolts from the inner tie arms to be removed. I would prefer to do this job on a ramp than axle stands personally. If the original bolts are ok, I see no reason why you need new ones?
    Rear Tie Arm Replacement-too adjustable camber arms "How To"
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,037
    It's not to bad to do the tie arms mate done mine in the dark last night with a lantern
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Quote Originally Posted by StaceyS3 View Post
    Did you change the top or bottom ones Stace?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Cool, maybe next weekend - the mrs will kill me if I work on the car on her day off
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Quote Originally Posted by jojo View Post
    Oh I just saw on one of the forums on my google mission that the bolts are one use. Personally I've only ever replaced head bolts...
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,037
    Top ones but have had bottoms off before and didn't find them much different
  1. How long to change rear pads and disks?
    By RobMorris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2012, 12:59
  2. Changing Rear Discs and Pads A4 2003 Conv
    By Audi-A4-Conv-2003 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2010, 16:14
  3. ARB and ARB link arm fitting help needed
    By afcjay in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2008, 22:52
  4. rear suspension arms and bushes
    By audii in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2007, 11:01
  5. Changing Rear Pads and Discs on S3
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2007, 22:59
