EM TuningVolks Autos
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
Like Tree7Likes
Thread: MK20 ABS Controller - Soft Coding
  1. #41
    Yohan87's Avatar
    May 2011
    404
    Cool. I brought my laptop and vcds cable to work today so I'll have a play at lunchtime
  3. #42
    Yohan87's Avatar
    May 2011
    404
    Quote Originally Posted by vfr800 View Post
    The VCDS knowledge base pages say that the coding options are well documented in the factory repair manual, there must be someone who has access to some proper VAG documentation and can help.
    Audi A3 (8L) Brake Electronics (MK20) - Ross-Tech Wiki
    I'm working on that
  4. #43
    Yohan87's Avatar
    May 2011
    404
    No joy.
    Tried all the codes posted earlier but whenever I click "Do-It!", it just goes back to the main ABS block screen and the soft code remains at 00214.
  5. #44
    Yohan87's Avatar
    May 2011
    404
    Quote Originally Posted by Yohan87 View Post
    I'm working on that
    Well the chap I know who works at VW had a look around the VW systems today to try and find any information about this but has hit a brick wall.
    In the mean time I've contacted Ross Tech and also Niki from R-Tech to see if they have any ideas.
    Westy likes this.
  6. #45
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    You would of thought so.
    2003 S3 BAM 225 Dolphin grey, Silk Nappa Leather, Bose, Cruise control.
    Mods; custom code stage 1, S3 8P gear knob, pipercross panel filter, APR diverter valve, Forge TIP, Powerflex bushes, R32 rear anti roll bar, spacers F 15mm R 20mm, haldex race controller, Bilstein b12 pro kit, Porsche 996 turbo brakes.
  7. #46
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    13 504 = 0b011010011000000 BORA 4M ABS/EDS
    13 404 = 0b011010001011100 BORA 4M ABS/EDS/ASR
    18 945 = 0b100101000000001 BORA 4M ABS/EDS/ASR/ESP
    18 443 = 0b100100000001011 SHARAN 7M AWD
    18 952 = 0b100101000001000 SHARAN 7M FWD
    18 448 = 0b100100000010000 S3
    18 446 = 0b100100000001110 TT
    For completeness here's 00214
    00 214 = 0b000000011010110
    Who know's what all this cr*p means.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  8. #47
    Yohan87's Avatar
    May 2011
    404
    Thanks Liam.
    It seems the MK60 guys can subtract 2048 (ESP bit) from their original codes to remove just ESP.
    My number seems so bloomin low to start with subtracting anything doesn't really seem like an option.
  9. #48
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    Thanks Liam.
    mine is mk20 and the 2048 code works just don't understand why yours is so low.
  10. #49
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Halfway down the page there are some options.
    ASR/ESP module coding with VDS-pro - Page 2 - TDIClub Forums
    I've quoted the content in case that page goes offline in the future.
    Controller coding
    STG 03 (brake electronics) select
    STG coding - > function 07
    03604 ABS (1J0907379 D/G - MKB: AHW/AKQ/APE/AGP/AXP)
    03504 ABS (1J0907379 P - MKB: AHW/AKQ/APE7AGP/AXP)
    03504 ABS (MKB: AEH/AKL/APF/AGN/AGU/AQA/ARZ/APK/AQY/AGZ/ATN/AUS)
    03304 ABS (MKB: AQM/AGR/ALH/AHF/ASV/AJM/ATD/AUY/ARL)
    03304 ABS (MKB: Mexico ALH/AHF)
    03604 ABS/EDS (1J0907379 E/H - MKB: AHW/AKQ/APE/AGP/AXP)
    03504 ABS/EDS (1J0907379 Q - MKB: AHW/AKQ/APE/AGP/AXP)
    13504 ABS/EDS (MKB: AEH/AKL/APF/AGN/AGU/AQA/ARZ/APK/AQY/AGZ/AQP/ATN/AUS/AUE)
    03304 ABS/EDS (MKB: AQM)
    13304 ABS/EDS (MKB: AGR/ALH/AHF/ASV/AJM/ATD/AUY/ARL)
    13504 ABS/EDS (MKB: Mexico ALH/AHF)
    13504 ABS/EDS (Haldex - 1J0907379 L/AA/AG - MKB:AGN/AGZ/AQP/AGR/AJM/ARL/AUE/ATD/AUY)
    13404 ABS/EDS/ASR (1J0907379 R/J/AF -MKB:AGN/AGU/AQA/ARZ/AQP/AGR/ALH/AHF/ASV/AJM/ARL/AUE/AUY)
    00214 ABS/EDS/ASR/ESP (Haldex)
    00241 ABS/EDS/ASR/ESP (electrical gas manipulation/1J0907379)
    00209 ABS/EDS/ASR/ESP (mechanical. Gas manipulation/1J0907379)
    10753 ABS/EDS/ASR/ESP (1C0907379 - MKB: AHW/AKQ/APE/AGN/AXP)
    10241 ABS/EDS/ASR/ESP (1C0907379 - MKB: AEH/AKL/APF/ATN/AUS/AWH)
    18945 ABS/EDS/ASR/ESP (1C0907379 - MKB: AGU/AQA/ARZ/AQP/AGP/AQM/AGR/ALH/AHF/ASV/AJM/ARL/AUE/ATD/AUY)
    18433 ABS/EDS/ASR/ESP (1C0907379 - MKB: APK/AQY/AGZ)
    Westy likes this.
  11. #50
    Yohan87's Avatar
    May 2011
    404
    Cheers Liam, I stumbled across that as well.
    Here is the first reply I've had from Ross Tech.
    "Based on the component field of this Mk20 ABS controller it appears to be a module specific to ESP and it is extremely unlikely that any conventional scan tool operation (coding or adaptation) modifications are going to have the desired results. Please send the complete Auto-Scan from this vehicle with the VIN for review."
  12. #51
    Yohan87's Avatar
    May 2011
    404
    Update from Ross Tech
    "Although it may not be correct, the PR codes per VIN and online parts management services of PartsLink24 show a MK60 ESP (1AT) ABS configuration for this vehicle. Was that Mk20 ABS module original equipment?
    In regards to the coding possibilities you may have more luck using repair information for the M.Y. 2000 Audi 8L1 (I used AMK/DQB details). That particular vehicle model appears to use several Mk20 and Mk60 variants with coding charts.
    In conclusion this module is ESP specific, and although I suspect it may not be the correct one, it cannot be modified using VCDS to remove ESP functions."
    I've asked for the repair information for the M.Y. 2000 Audi 8L1 that she mentions.
    What would happen if I fitted a Mk60 controller to my car?
  13. #52
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I disabled my ESP today. I'll let you know how it is on track tomorrow.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  14. #53
    Yohan87's Avatar
    May 2011
    404
    Quote Originally Posted by Westy View Post
    How did you get on Westy?
  15. #54
    Westy's Avatar
    Dec 2008
    17,273
    Works really well. Tam also did back to back tests comparing it with using the button and it does seem to only disable the ESP and nothing else. Reesy said he thought his car was really lively and thought it must disable more then just esp. I'm just glad I don't have to hit the button every time I te in the car
    S3 Build Thread
  16. #55
    Yohan87's Avatar
    May 2011
    404
    That's good to hear.
    Rub it in why don't you
    Westy likes this.
  17. #56
    Yohan87's Avatar
    May 2011
    404
    Update from Ross Tech.
    "The other modules used in Mk20 and Mk60 systems aren't usually compatible with each other but I do not have any personal experience with that particular retrofit.
    If this is for track/off road only I would personally consider experimenting with some non ESP Mk20 modules and see if they behave with the engine management system so you have normal braking. As you likely know, vehicles without the old-school proportioning valve in the rear axle need the ABS module for base/safety functions of brake fluid proportioning so you cannot simply unplug the ABS module.
    We are not able to provide repair information including for example coding charts, wiring diagrams, component location schematics or TPI/TSBs which are copyrighted material belonging to VW/Audi. The Official Factory Repair Information sources are listed here:
    Official Factory Repair Information - Ross-Tech Wiki
    Subscription based parts management information is available through PL24 and linked here with our PR code explanation:
    Production Codes (PR-Codes) can be found on the Vehicle Data Label - Ross-Tech Wiki
    It looks like I failed to note previously that you can edit the AutoScan.txt file to eliminate modules that aren't installed. This file is located in the VCDS directory when looking manually and also linked from the Auto-Scan function screen. This is briefly mentioned on the following page:
    Ross-Tech: VCDS Tour: Auto-Scan"
  18. #57
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    Did you try the 00016 code to switch off EDL as well as the esp? Not that i too sure it that is a good thing of a bad thing.
    I tried it once but couldn't tell much of a difference
  19. #58
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by rhys1210 View Post
    No mate I never tried it as the car is nice to drive with just the ESP off.
    S3 Build Thread
  20. #59
    phil miller's Avatar
    Sep 2012
    Devon
    843
    im gonna have a play with Ron now he is home
  21. #60
    Sep 2012
    Devon
    843
    gonna try this now
    ​Wish Rachel would let me have my TDI mk5 back
  1. HELP, I changed coding I should not have. Audi A3 Abs Controller.
    By johal87 in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th January 2011, 16:21
  2. Can't change SOFT CODE
    By Tinpusher in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th November 2006, 23:31
  3. help !!! 1600 for ABS controller ?
    By sa8ahwe in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2005, 18:41
  4. Fitting a ABS CONTROL UNIT!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2005, 22:30
  5. A3 T Climate controle Factory Codes
    By razor in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 17:05
