Thread: Speaker size
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Speaker size
    well today i purchased some speaker adaptors off the renound andy mac i am going to fit a set of 6.5in coaxials in the the rear and a set of 5.25 components in the front and then use a 4 channel amp to get the most out of them, im stuck between inphase and hertz as i had inphase in the last car and was really impressed with the quality but i have heard really good reports about hertz.
    your opinions?? I was worried about the depth of the speakers and wondered if anybody knew what the deepest depth speaker is able to be fitted in both the front and rear? if other members have any pictures of their speaker setups i would like to see some photos please.
    as soon as i get the adaptors and speakers etc i will post some pictures with my choice and also of the install.
    by the way this will be getting fitted into a pre-facelift s3
    BRING ON THE WET WEATHER ​QUATTRO FTW
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    The main issue the depth of the speakers. My Hertz component speakers would not fit within the front doors, so I had to cut the doorcards and mount the grill out of the doorcard. I sealed them in with sound deadening and they sound great.Max depth is just over 50mm so quite shallow which was my problem because I already had the speakers.
    Also on the subject of speaker adaptors, I had no issue fitting rears as there is more depth to use, but with the front I didn't even need adaptors as I cut the doorcard and drilled my own holes to mount the drivers.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Jun 2003
    World of my own
    9,813
    Depth in the front using the MDF adapters is between 55-60mm depending on the chunkiness of the magnet.
    Rear depth is not an issue there is loads of space.
    Alex Turner
  1. speaker size
    By a3kid in forum In-Car Entertainment
    Last Post: 7th June 2005, 22:36
  2. speaker sizes for Cabriolet 1997?
    By imported_silversurfer7 in forum Classic Audi Forum
    Last Post: 12th March 2005, 08:00
  3. A4 speaker sizes ???
    By myzeneye in forum In-Car Entertainment
    Last Post: 21st November 2004, 22:06
  4. Speaker Sizes
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2004, 10:55
  5. S3 Speaker sizes.
    Last Post: 21st May 2004, 23:43
